  New Posts New Posts RSS Feed - propeller maint
propeller maint
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: propeller maint
    Posted: October-22-2015 at 12:16am
I have to learn to type faster-----
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2015 at 12:15am
Welcome Wayne,you have found the right place for help.When you get a chance,post up some pictures of your boat. If you are talking about where the shaft passes thru the strut right in front of the prop that is called the cutlass. It is water lubricated and that is why it is important not to put it in gear when out of the water. You should grab the prop and see if the shaft moves sideways or up and down in that bearing. Too much movement and it needs to be replaced
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2015 at 12:10am
Wayne,
There aren't any since both the cutlass and the shaft gland packing are water lubricated.
Welcome to CCfan. We'd love pictures.
route66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote route66 Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2015 at 12:01am
hi. can anyone out there help me.. i do not see any grease zerts or oiling spots for my propeller shaft on a 1970 correct craft skier. what is the suggested maint. thanks wayne
