  New Posts New Posts RSS Feed - 2005 Nautique 196 Guages
frozenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Topic: 2005 Nautique 196 Guages
    Posted: June-06-2016 at 4:47pm
Back to gauges. Put boat in a few weeks ago, checked gateway box, all connections seem tight. But before checking I noticed that the Temp guage was working, but not consistently. Seems to work ok then the next time out it doesn't, the volt guage is still non operational all the time. Ideas?
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2015 at 5:20pm
Originally posted by quinner quinner wrote:
Also a good idea at winterizing to pull the pitot lines at the bottom of the gateway box, they are supposed to self drain, but if they do not, will freeze and back up water into the gateway and smoke the circuit board.
If your boat will see freezing temps during lay up you may want to consider doing as noted above. The first winter with my 05' I was not aware of this issue and my gateway was toast after a couple uses the following spring, fortunately was covered under warranty.
What makes this issue a bit more critical is replacement gateways are no longer available from what I understand. Since I had that problem I actually remove my gateway during layup so it can be stored inside in a climate controlled environment.
BTW, nice looking tug!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2015 at 4:39pm
I am not a whiz on the computer, tried uploading photos of boat and dash. boat went into storage today so any repairs will have to wait until spring.
The Godfather View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Godfather Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 9:36pm
Post a photo of your dash gauges, then we can see what next to check .
Jbear, said to me wow if it was'nt for this site we would never had met for this to happen....
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 9:03pm
Then you have digital gauges, check the gateway box, should be in the trunk, possibly attached to the liftring ring threaded rod. There will be a couple pitot lines for the speedos and then several various sized shaped plugs for the gauges, pp, etc.
Make sure all the plugs are clean, plugged in and pushed in tight.
Also a good idea at winterizing the pull the pitot tubes, they are supposed to self drain but if do not will freeze and back up water into the gateway and smoke the circuit board.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 6:25pm
Keypad, but would rather have a key, the code is a PITA everytime I go to start it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 2:25pm
Do you have a key or a keypad? That will help me determine what trim level and gauges you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 2:15pm
Not sure what the trim level is, I think it is the limited. How would I be able to tell?
The gauges are not digital. What is the Gateway box and where is it located?
And how does the dash come off? Looks like there are 3 or 4 botls on the exterior of the dash, just take those off? Does the steering wheel need to come off too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 1:55pm
What trim level is the boat, Team - Limited or Signature?
If you have digital gauges (Team or Limited) check your gateway box connections
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2015 at 12:21pm
I doubt it is fuses, but could be a connection or a corrosion issue. Yes, you have to remove that pod to get behind the dash to the gauges.
Congrats on your new boat. Pics or it didn't happen!
Post Options Post Options   Thanks (0) Thanks(0)   Quote frozenskier Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2015 at 4:29pm
Just purchased an 05 196, previous boat 1989 Nautique 2001 model. Obviously the new boat is more complex. I have 2 gauges on the right hand side that are not working, volts and Temperature. The odd part is that when the dash lights are on these 2 gauges don't even light up. Just wondering if this could be a simple electrical connection or fuse problem. Stuck my head under the dash but didn't see any way to get at the gauges, will I have to take the whole dash off to get to them? And I'm afraid to ask what that might entail or if I would need to take it to a mechanic to have it done?
Suggestions?, I am fairly competent at mechanical issues, on old boat I would do oil changes, winterize, replace thermostat, impeller, plugs, points, adjust through hull fitting, etc   Thanks
