  New Posts New Posts RSS Feed - Change  gas pedal to hand throttle??
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Topic: Change gas pedal to hand throttle??
    Posted: June-13-2006 at 6:52pm
Mv2 is a new one and will work great...
if you want to keep it retro(and spend much less)....see item # 4649856354 on ebay. That one is the late 60's and 70's long handle ....a new knob and your rollin!
I have purchased two recently ...each for under well $50.00
The black housing can be painted if needed!
stang
The Super Air
Atmspltr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atmspltr Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2006 at 3:32pm
Morse MV2
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2006 at 12:19pm
The older style had longer handles...later 70's and up were shorter...look through diaries sect and see what looks good!
On ebay...look for a single Three position...rev , nuetral,forward...side mount style. I see them all the time and have purchsed a couple. You can repaint the housing too.
stang
The Super Air
FFtwentythree View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FFtwentythree Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2006 at 11:16am
Which morse control should I use???
1966 Correct Craft Mustang
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2006 at 11:10pm
Could use an century type cable thru dash.You can push center button and pull or rotate for fine adjustment.
My buddy Wally's mustang has been converted to single hand, typical nautique style shift and throtle the gas pedal and cable are still in place we have tried to think of a way to have both hooked up so if you needed a little speed in the corner you could use the foot feed and then let it come back to the set speed on the hand control looked at all kinds of tranny kick down cables etc. so far just an idea though
good luck MUNDAY
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atmspltr Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2006 at 10:24pm
Did it on my 67 Mustang. The gas pedal was cool but difficult to keep constant spped in wake and no way to seat on back of seat and drive. Easy to do...as described above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2006 at 1:07am
See paul waters 63 classic in the diaries sect...he has done just that. The morse control hand throttle can be mounted on the side of the gunwhale.....you will need to cut out an area through the glass that matches the contol housing section and drill 3 holes.It should not entail much!
I am considering doing the same on my 62.
The control units are offered on ebay fequently!
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote FFtwentythree Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2006 at 6:47pm
Hey just looking for some info on this has any one done it or have suggestions on what the best route is I have always had a hand throttle and I bought this sweet 68 stang and I want to keep the column shift an leave the pedal on the floor but just use a throttle only control any help greatly appreciated thanks
