Quick Release '02 |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13517 |
Posted: December-28-2015 at 1:51am |
2" diameter it is!
skibum1110
Senior Member Joined: October-21-2007 Location: Lakeland, FL Status: Offline Points: 256 |
D&C. Got it today. Perfect fit for my 2000 SN. Thanks
1992 Ski Nautique
1975 Ski Nautique 2000 Ski Nautique 2006 Ski Nautique 206 Limited 2005 Air Nautique 206 Team |
DanaV
Newbie Joined: December-04-2015 Location: Sarasota Status: Offline Points: 5 |
I'm still looking for a used release if anyone has one to sell. Prefer 2 pin
Hollywood
Finally looked at this on my computer monitor zoomed in and I do think this is for a 2" pylon... It's tightened down further than it will be on the pylon, need to measure the diameter up and down, with the split (which does not change), and maybe not blocking the actual diameter...
D&C1988
Groupie Joined: February-16-2015 Location: TableRock Lake Status: Offline Points: 67 |
It's on the way Priority mail USPS.
Thanks Good luck !!! |
D&C1988
Sale pending to another member who saw the post.....
DanaV
bummer the dia is too small
thanks for the pic |
D&C1988
Sorry picked same one twice. |
D&C1988
David 636-294-3673 |
D&C1988
DanaV
Yes, a double is what I am looking for. Send a pic please. How much are you asking?
D&C1988
I can put up some pictures later tonight when I get home.
skibum1110
D&C I might be interested in your double release. Do u have any more info on it? Pics?
1992 Ski Nautique
D&C1988
I have one at home that is a double. Not sure it is what you want but can send a pic or you call call me after 6pm central weekdays.
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Used release has a 1-3/4 bore and will not fit your application
'88 BFN |
NCH20SKIER
The Lake Elmo' used release may have been on FB under show ski equipment for sale (?). In any event a call to Chick will clarify if they have a used release and whether or not it will fit the application
'88 BFN |
Hollywood
I don't see anything under Used at Lake Elmo.
You're looking for 2" diameter, the spot below the rope notch and above the full thickness of the pylon. For trick or swivel you can use rope, else bite the bullet and buy a release before someone gets hurt. Elbert's (A.R.E Manufacturing) also used to make releases called GUARDIAN. |
NCH20SKIER
Actually I think Lake Elmo has a used one for sale that may work.
Both Lake Elmo and Weyers Custom Handles sells the KW release's. You could also check with Ron Beeman (in FL) who also makes releases. Good Luck |
'88 BFN |
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
Lake Elmo Sports
DanaV
Just bought an CB196 '02, looking for a quick release (single or double) to use in show skiing!
