Lift ring brkt. |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Posted: January-08-2016 at 7:54pm |
Wow! Hard to believe how much of the metal rusted away. I need to take a look at mine!
83Ski
Duane in Indy
Thought I'd share some pics of what was encased within my foam in the bow. The lift ring brkt. looked fine above the foam line, BUT look at what was inside. I fabbed a new brkt. with a "tongue" on the bottom to glass into the hull and a cross piece that the floor sits on. If the brkt were to pull loose from the hull then the floor would help hold it in position. Will glass the floor in the weekend. Welded the new brkt to the old one best as poss.
1978 Mustang (modified) |
