Arbor tool adapter |
Author | |||
Posted: January-28-2016 at 7:55am |
Chris,
Yes, I appreciate your input as well. It too has been noted and taken seriously. Thank you. |
quinner
Well now that the arbor tool has been inserted perhaps something else to think about is calling out a member as NG or not given if they choose not to include a name in their profile. Maybe it's just me but it sure does not come across as friendly or welcoming in any way.
Joe,
I very much appreciate your comments and thoughts. I have not taken them lightly but rather very seriously. Thanks. |
JoeinNY
You are simply delusional - you came off as a belittling know it all jerk - your final hint to this should have been when he posted that no further reply was needed. You replied almost instantly, then posts disappeared. It is not a debate to simply discount someone's solution because you don't feel there was a problem. You are a smart guy Pete and I like you, but you scare people away from this site by feeling the need to question everything posted to the nth degree sometimes with two or three posts in a row. You don't know who these people are and what they know or how they know it - and they owe you no explanation. Debate is allowed but not always required - when someone is obviously not amused and they started the thread then leave them alone. |
Peter,
I see it often when guards have been removed so you must use one of these plus, do not wear gloves. Still, you are correct that just the sight of them is scary . |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
God that thing scares me....it's a rotary chainsaw! At least with a friggin chainsaw you've got the thing "out there" away from yourself! I'm not as worried about my fingers as I would be about my forehead! Seriously looks like something from a horror movie.....
2008 MasterCraft 197TT
1996 Nautique Super Sport 1988 Waterlogged Supra Mariah |
I'll get ziggster's print on his design and chuck up some bar stock. |
Hollywood
damnit pete now you owe me an arbor tool adapter
Because I asked him the following?
BTW, he deleted posts that I wasn't even involved in! Aren't forums open to debate? Something else is going on. |
quinner
That's not good, looks like he may have actually deleted his entire existence, not just his posts?? Geez Pete, if that is the case you need to put yourself on a time out if you cannot behave!! |
JoeinNY
I suspect he's deleting his posts because no matter what he posts you follow up with some reason why it is wrong every time, and being a rational person who doesn't feel the need to argue everything on the internet he is just running away from you...
The ziggster keeps deleting his posts! If you do a search for his older posts, you'll find all they are exclamation points I sure because they when past the time limit for a complete delete. |
Waterdog
I'm sick - That made me giggle |
DrCC
Where'd the picture go ?
I wanted to add this one. Wanted to buy this one when I was making the crooked paddle, but every time I looked at the Lancelot I could imagine my fingers flying off into the yard. |
Correct since I'm just a hobbyist. |
Paul,
An electric drill can be used but an electric variable speed die grinder is more comfortable. They are designed so you can get both hands in a better position. |
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
Pete, what tool do you use the 3m earaser with? A drill, a dremell? Says you should operate it around 2000rpm.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
A 3M eraser wheel would have been easier than Dent Fix trying to stick it in!
NA,
They don't have an adapter? What is the recommended tool the decal wheel is intended for? |
