ignition counter rotation |
Author | |||
Air206
Posted: February-11-2016 at 4:35pm |
Tim -
I just read what I typed - Doh! You are right, RH 454 is what I have only seen. Stupid. Mine is PRK-WR-R10T. |
nico schaap
Newbie Joined: February-11-2016 Location: netherlands Status: Offline Points: 6 |
that's the answer i was looking for!!!!
thank you all for your help on this. will let you know if and when it works.. have a great day and greetings from Holland. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21171 |
Pull the trigger and measure the shaft diameter. You may be able to reuse the RH gear on a new distributor. That is the only piece that is rotation specific.
nico schaap
this one is a Ford 351W counter reversed rotation.
100% shore it is. just need a @#$%$#@ distributor. |
Pretty sure Mark from N3's '91 footer has a RH 454, Steve. You're saying yours is a lefty?
The 351w I pulled out of my '91 excel is a righty as well. I'd be curious to know when they switched... And what ratio v-drives went with what. I think there may have been both 1.25:1 and 1.5:1? |
Air206
Not so fast my friends. Excels had both Righties and Lefties mated to their V-Drives. The 351s varied R and L, but I haven't seen a lefty Chevy. (EDIT- Read what I actually typed! Ha!) They were the PCM transition phase to the wake boats' SuperSport/SAN210 V-drive, all lefty engines. The key here is his engine tag: :PRD-WR-R10T - always helpful! Performance Distributors' DUI is a nice unit. I'll let you know what I think about it in a 454 if I ever make the swap. It was sweet in the 350 chevy in the Tique. |
Duane in Indy
The distributor turns CCW looking down on the cap no matter whether the engine is CCW or CC rotation. I used a Mallory (which was just bought out by MSD). IF you do choose a new distributor just make sure your coil is the correct OHMS. Might be best to diagnose your setup first and then determine whether to replace or rebuild. Duane
edit: OOPS, I assume it's a Ford? |
1978 Mustang (modified) |
Orlando76
Ahh, reading comprehension. |
backfoot100
Not in a V-Drive. |
Eddie |
Orlando76
92 Pro tec is a lefty. RR gear not an issue.
nico schaap
so that means i can use a standard rotation distributor and only change the gear to have it running again?
what type of distributor/coil you recommand for my boat? |
Duane in Indy
If you decide to convert to a distributor/coil set up: Many on here have bought conventional distributors and just replaced the gear with a reverse rotation gear. I just converted one for a member this month. You may be able to reuse your gear. Or I have a spare RR gear. Just need to check the shaft size. Duane
nico schaap
i tested the system and when engine is cold i can go up to 4200 rpm.
when it heats up max is 22oo rpm. tried taking of knock sensor, temp and oil press alarm but no difference. leaves the coil pack/computer to be bad. did this several times but never had a reverse rotation and there is the problem. can't find the right conventional distibutor with coil. |
JPASS
Most people with ProTec issues will simply replace the system with a distributor and coil set-up.
The ignition swap tutorial is a good place to see what's involved. This thread goes over a bunch of questions that were asking prior to the swap. I do know that another member is selling his old ProTec coil pack here What symptoms are you having that makes you think the system is bad? |
'92 Correctcraft Ski Nautique
nico schaap
hello.
i have a nautique exel 1992 with a protec ignition system. i need a replacement for this one. i can not find it because the engine is reverse rotation and protec is no longer availeble. model:PRD-WR-R10T serial:312563 firing order:18456273 looking from the flywheel the engine rotates to the right [cranck pulley and camshaft] the distributor rotates to the left. any ideas????? |
