  New Posts New Posts RSS Feed - Cutlass alignment, rudder shaft seal
mandovoodoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mandovoodoo Quote  Post ReplyReply Direct Link To This Post Topic: Cutlass alignment, rudder shaft seal
    Posted: June-11-2006 at 10:17pm
On close inspection I really couldn't see any problem with the cutlass. Maybe it is just worn in that way! I'll tear it down in the fall when I pull the boat for the winter.
Got my fresh 13x13 on, everything is clean and waxed. Boat runs very nicely. Quiet. Runs flatter, too.
www.mandovoodoo.com
mandolin research
1986 Martinique, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote mandovoodoo Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2006 at 12:47pm
The shaft is essentially perfectly centered in the thru hole hull. Everything looks nice except the strut, which appears to have taken a strike at one point before I got the beast. I suppose I'll yank it all apart and see what's what. Perhaps the strut attaches in a manner allowing adjustment.
I'll also look for the stuffing box for the rudder. Should be fun upside down work!
www.mandovoodoo.com
mandolin research
1986 Martinique, TN
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2006 at 12:31pm
rudder stuffing compresses same as shaft,thats the easy one.
On shaft and vibration.Is the shaft centered in thru hull hole?If it is you may have strut alianment issues.To check shaft alianment you break loose four bolts holding coupler to back of trany and check with feeler gauge should to within .003,top bottom left and right.The cutlass is very tight in the bore there isn't anything you can allign there without removing strut.
Hope that helps
Good luck Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote mandovoodoo Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2006 at 8:52am
Greetings again,
'86 Martinique out of the water, checking for vibration cause (not much). Slight tip damage on one blade, so I think that's the source.
However, strut is aligned so that shaft is not centered in the openings at the ends. No shake, shaft turns freely. Shaft is closer to port on one end, starboard on the other. Is the cutlass bearing within the strut end self aligning, or is this a misaligned strut that I need to relocate in perfect alignment with a new cutlass bearing? I suppose I can get it off!
Second, only place I could immediately see bilge water seeping possibly is at the rudder shaft. This does have shake in it, just a little. This is not an obvious adjustment. Is there packing? Easiest way to adjust/compress? I am shipping water slowly and steadily at anchor & running, about 2 pints/hour.
Thanks for any suggestions. I miss my boat already, beautiful day. But I am pressure washing and buffing it.
www.mandovoodoo.com
mandolin research
1986 Martinique, TN
