Engine Dies 2003 Air Natique 216 |
sweaver36
Newbie Joined: June-27-2016 Location: TEXAS Status: Offline Points: 21 |
Posted: July-09-2016 at 12:00am |
Ok I am clueless!!
I replaced Anit siphon valve Replaced Both Fuel lines and Connected LPP to Anti Siphon valve on top of tank Looked for Skinned wire by throttle and is good. Checked Vent Lines Went through all electrical and haven't found anything Took it out today and throttled up and it immediately died and would not restart Opened gas cap to see if it would restart and no luck I think I made problem worse |
THANKS
sweaver36
There are two fuel lines. Which one is connected to valve on top of tank. There is red paint on top of valve on tank?
THANKS
sweaver36
What is the PME?
THANKS
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2106 |
Unlike the previous GT-engines the 2002 plus Excalibur get's it's ignition power run through a 10 gauge wire direct from the battery to the PME box. where that wire comes up from the battery box through the "Air" box Behind the kick panel is the same orifice that the steering cable goes through as it routs to the bilge towards the back. I have seen after replacement of the steering cable that red wire can get skinned and or dammaged even to a intermittent fail. Also check the PME for a loose connection both ground and power.
quinner
Jody, curious where you are going with the steering cable question, do tell!!
sweaver36
Has the steering cable been replaced? Not that I am aware of Does the fuel pumps cycle when keyed up?will check Do you have a fuel pressure gauge/ reading?no Has the engine been scanned?not lately |
THANKS
Fl Inboards
A few questions?
Has the steering cable been replaced? Does the fuel pumps cycle when keyed up? Do you have a fuel pressure gauge/ reading? Has the engine been scanned? |
quinner
Neither, should be right at the elbow on the fuel pickup line at the top of the fuel tank.
From there lines should run to the LPP, from there to the FCC, HPP pumps from the FCC. Check from the tank to the LPP for an inline filter, some years had them and some did not?? |
sweaver36
Does the anti siphon valve attach to LPP or HPP
THANKS
sweaver36
They did replace hpp and fcc filter. I did jump out lanyard and still have issues. I think I will replace fuel lines, plugs and wires.
THANKS
quinner
ZR6 is a coil pack so nothing you can really do there, I would get a new set of plugs and try that. I would also trace the fuel line from the tank to the LPP and see if there is an inline fuel filter along the way. The FCC should be serviceable, the HPP and FCC filter is inside it. If they replaced the entire unit you should have a new filter, if they only replaced the pump could be worth changing that filter also. Also be a good idea to make sure your lanyard is OK, it's easy to make a bypass, couple spade connectors and a short bit of wire
sweaver36
The dealer replaced them for free.
The FCC is all one unit with filter and pump all of it was replaced by dealer. Motor is a ZR6 made by PCM. I think it is a coil pack ignition It turns over but will not run. |
THANKS
quinner
I would be calling the dealer about the 2 pumps they replaced that were not bad, ouch.
When was the FCC filter last changed? What motor do you have, most likely either 330hp Excalibur (silver shroud on top) or 370hp 6 liter unless it has a Python?? If Excal inspect the cap & rotor, same for the 6.0L although that may have a coil pack style ignition, not sure? Where you mention it would not even turn over points more towards check battery, cables/connections, etc.?? |
sweaver36
I checked anti siphon valve with ball in it and its good
I checked gas tank vent hose and its clear. |
THANKS
sweaver36
Need help
2003 Air Natique 216 PCM 400hp engine Purchased boat a few months ago and it would run for about 30 min and it would stall out at high speed. Dealer replaced high and low pressure fuel pump and said it was fixed. I haven't been able to test it because of flooding waters. I took it out this weekend and now it ran for 30-45 min and started to stall at high speed then it would also not crank. I let it set 10 min and it would start right up.. Ran it slow for about 5-10 min and it would die. I would have to let it set for 10 min before it will crank back up. Any Ideas? |
THANKS
