  New Posts New Posts RSS Feed - GT-40 Saga Continues
RIPnSIX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPnSIX Quote  Post ReplyReply Direct Link To This Post Topic: GT-40 Saga Continues
    Posted: July-18-2016 at 5:46pm
yes, my original pump has the two brass connectors on the bottom..
My new pump has a plastic plug connector on it..
I'm not sure how to post pictures. but it's this pump.
http://www.nautiqueparts.com/fuelpumpelectricsupply.aspx
If you don't fall, you're not trying hard enough.
If it doesn't hurt.. Go Bigger.
Tubing Sucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2016 at 5:26pm
Don't those leads mount to the pump with screw terminals on the bottom of the pump? I have never had mine off but some time in it's past the pump was changed by the dealer= top of picture in the middle are the connections
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPnSIX Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2016 at 5:02pm
I am replacing my LPFP today, I will also be installing a inline filter.
My new pump has a different connector on it than factory, Does anyone have the part number of the mating connector? Or what is the best way to connect the new pump to the old harness?
Tubing Sucks.
leftseat88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2016 at 6:29pm
$18 relay fixed the problem. Thanks Boys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2016 at 12:03pm
You can jump the fuel pumps to run continually to help trouble shoot.
What fuel pressure are you getting when key is turned on?
Here is a picture of the jumper for the pumps
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2016 at 4:35am
Maybe your low pressure pump has died? Give it direct 12V feed and see if it runs or at least verify it has 12V when the key is turned on. Remember you will only have 12V at the pump for 3 seconds after the key is turned on to pressurize the system. After 3 seconds if your engine is not running the pump is designed to shut off.in normal operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2016 at 10:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2016 at 10:48pm
Short an simple:
Motor won't fire. Motor will turn over. Replaced the low pressure fuel pump. Try swapping the relays, pump relay and computer relay. I'm getting power to the relays but no power to the low pressure pump. Kill switch is correct. Fuses are good. Strong battery. I cannot hear the pump turn on during ingnition.
What is the deal!!
