Commander 351 tstat housing |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1846 |
Posted: June-21-2006 at 10:44am |
ah ha...thanks
BINGO. They essentially have the exact housing. It's on the way. Thanks so much '79 |
79nautique
oscomotors.com
ultrarunner
and the url? cause OSCO.com is not it.
79nautique
osco makes the housing you need to work check out there website
ultrarunner
Here is the picture folks.
thanks http://www.flickr.com/photo_zoom.gne?id=166833229&size=l |
ultrarunner
I have a wicked crappy connection here at the hotel in ACY. I'll try to post a picture this evening. I have a good one showing the entire housing as it sits on the engine. |
79nautique
what size hose connects to the exhaust manifolds? if it is 1" or 3/4" hose (can't remember exactly) then the PCM should work. I'm going on the assumption that it is the housing that mounts to the intake and has a 1-1/4" hose going to the bottom housing that holds the t-stat and a upper housing that has three 1" lines one from the RWP and one each to the exhaust mainfolds.
Can you take a picture and post it here so we can have a better understanding of what your running into. |
ultrarunner
Which brand? Skidim was talking adapters, compatibility...maybe having to use different size hoses, etc.... Maybe I had the wrong guy on the horn. What do I need to get from them, and I'll get it coming. |
79nautique
just buy the lower housing and upper housing from skidim and be done with it. The odds of finding a commander are slim and none.
GottaSki
Call PartMan - no nevermind - they got crusader
River Rat to Mole |
ultrarunner
I know...I could take this to a sharp welder and have it redone, but if I could find a good unit, that would be preferable.
Any ideas on a source of Commander parts? |
Tim D
It may be hard to find one.
Tim D
ultrarunner
Yes, the upper portion of the housing splits..each side going to it's respective cooling jacket. |
Tim D
Not what I meant, does it split to a T?
Tim D
ultrarunner
Yes it does Tim, in order to facilitate changing the tstat. |
Tim D
Does your housing split?
Tim D
ultrarunner
I posted in general, but I'll be more specific here...
When doing some hose replacement, I noticed a fair amount of corrosion around and inside of the thermostat housing. I removed the housing from the case and also removed the top of the housing to expose the tstat. The tstat was frozen in the housing and when I removed it, some of the seat came with it, which was no surprise. The housing is likely usable however I would rather replace the housing. Is there a source for servicable Commander parts? Are there any other options such as using an Indmar or PCM Tstat housing? This is a Ford Commander 351. thanks |
