  New Posts New Posts RSS Feed - carpet install
carpet install
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Topic: carpet install
    Posted: September-26-2016 at 3:02pm
For my FB followers you might know im almost done with the skins and carpet replacement, but I owe you guys an update.
I will have it ready this week, hopefully will use it next weekend.
I will update pictures soon.
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2016 at 4:39pm
no updates lately here, but some progress, will post pictures later.
The guy doing the job is having a hard time removing the old carpet from the floor, Is it possible contact cement to stick more to epoxy resin?
side wall carpet was removed without any issue but the floor carpet is severely difficult to pull out! Toluen is a cement glue remover, but can it affect the cured epoxy resin? I was considering usind the toluene to try to soften the old glue....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2016 at 12:44am
That carpet is the one I put 5years ago when I did the stringer. Local bs crap.
Im replacing it with Oem one I brought with the skins...
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2016 at 7:52pm
I've seen that interior before (when we redid ours). lol.
Is that the new carpet?
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2016 at 5:46pm
Boat w/o upholstery, Took it to another marina to have the hull polishe, and to fix some chips and dents,
I ordered a new stereo system also.
Bike is to return back to pick the car!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2016 at 5:43pm
ttt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2016 at 4:43pm
Seb,
Mix equal parts with both the hardener and the resin before combining the two. That way you won't goof up the mix ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2016 at 4:22pm
I have the epoxy resin and it hardener, Nad the Toluene.
So to use it I need to mix the toluene with the herdener , and them misx it up with the resin correct.?
We are heving average 50º temperatures here, so this will slow down the curing process, or I need to change the mixing ratios? }o better raise the temperature to the 60º-65º
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2016 at 12:38pm
I would definitely try the Toluene and maybe experiment a little. Sometimes, whether due to my mixing ratio or environmental variables, the Xylene mixture would feel kind of tacky/gummy when cured. Like the Xylene didn't evaporate off quick enough to allow the epoxy to cure to full hardness. It still was watertight so mission accomplished, but it wasn't quite the same as the Rot Doctor CPES.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2016 at 12:13pm
Originally posted by C-Bass C-Bass wrote:
I thought Xylene was the solvent of choice for home brew CPES. I've used it before and had good results. Never tried acetone or anything else, so not saying those won't work.
Craig,
Xylene and Toluene are very close with their solvency and evaporation rate. Xylene is just a tad bit slower than the Toluene.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2016 at 11:01am
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2016 at 6:23pm
I thougt its the epoxy resin and the herdener they sell.
So it should be a two part epoxy and the hardener?
I will see what I can get at the resin shop!
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2016 at 6:18pm
note that the prior skin replacement I had, MF used regular staples, wich are pita to remove now as they are rusted, not a problem now as I will be using new wood!
Now I will have SS staples!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2016 at 6:16pm
Seb,
Mix the acetone or for a slower mix toluene, with the resin and hardener first. Then when you are ready to use it, mix the two epoxy components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2016 at 6:08pm
so the thinga started, still chasing some wood rot!
all my seat and coaming pad backing are shot!
will need to fab new.
I will have neew wood cut and plan on coating it with the home brew CPES...
about that its a 50/50 mix of epoxy resin and acetone?
the resin has to be activated prior to mix it to the acetone?
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2016 at 6:58pm
That might be enough to do two boats if you're really frugal with it! lOl. You know we like pics from Argentina.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2016 at 5:19pm
actually its 10 yards and 8 1/2 foot wide..
George from Christines told me it should do the complete boat...
hope it does!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2016 at 5:15pm
Well
after almost 2 years of having the skins stored at home, I decided to go ahead and have them installed.
I will be replacing some of the foams in the worned seat cushions, and also replacing the carpet.
I bought a 12 yard long x 8 ft wide carpet roll, it is supposed to be enough I hope for the whole boat.
Now my question is how Im I supposed to lay it to make full profit of it?
Tomorrow I´m taking pictures to show the before and after!!
now the interior is completely shot!
