  New Posts New Posts RSS Feed - Starter Issues
Starter Issues
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Starter Issues
    Posted: July-17-2016 at 6:51am
Originally posted by cmacbuck69 cmacbuck69 wrote:
The holes in the lever seam to sit on the pinion ears snugly, but the leaver is a little loose maybe where it attaches in the solenoid.
The looseness of the two leavers from the solenoid was my first thought. Check deeper especially at the leaver pivot points.
cmacbuck69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmacbuck69 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2016 at 11:14pm
The holes in the lever seam to sit on the pinion ears snugly, but the leaver is a little loose maybe where it attaches in the solenoid. The reason I am not just buying a new starter is that it's maybe 2 years old and it's the correct marine starter for my boat purchased from Skidim... The motor and solenoid seam to be working fine so I'm reluctant to buy another new starter without going through this process...
Lakeview View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2016 at 6:56pm
Sounds like too much play in the attach point-any loose pieces when disassembled?Was it a rebuilt marine starter?
Lakeview
1992 Barefoot Nautique
1967 Barracuda SS
1967 Chris Craft Cavalier
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmacbuck69 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2016 at 12:42pm
My starter has been acting up recently. I always do a quick dry start in the driveway to make sure all is well before heading to the creak and a few weeks ago the starter the motor would just spin when I turned the key. After a few attempts the solenoid engaged the drive pinion and the boat started, BUT the drive pinion did not fully disengage so it was clanking on the flywheel. I took the starter apart and found that the drive lever popped off the armature clutch on one side, which explained why it did not fully disengage. I popped the lever back on and it seamed good to go. On the next trip to the creek after 5 or 6 six starts later it did the same thing. I was able to fix it on the water, but any idea why this is happening? I have attached a photo in the event my terminology is inaccurate. The boat is an 83 SN and the starter is maybe 2 years old.
