  New Posts New Posts RSS Feed - Can the lifting rings be trusted on unrestored CC'
Joby1969 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joby1969 Quote  Post ReplyReply Direct Link To This Post Topic: Can the lifting rings be trusted on unrestored CC'
    Posted: July-22-2016 at 8:18pm
mine was solid and its a florida boat,. the issue will be what is it attached to that you cant see.BTW its a 1980
my 1980 SN is mad at my 2009 HD
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:46am
Mine looked like Duanes. The strap snapped right off when I tried to unscrew the ring. Florida boat, consider the source.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:21am
The general rule is they will be fine- on an 82 unless the boat was super duper salty and abused I would be shocked to find the rings compromised… get under and take a look if you get a chance but you should be fine.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 9:47am
Originally posted by Warpman89 Warpman89 wrote:
Hello, what's the general rule with lifting rings on older boats? My '82 BFN is unrestored and it shows, what should I look for to check integrity? Thank you
Bow bracket on my Mustang 17 when I removed the foam.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2016 at 11:22pm
Stu,
Drill some small holes into the wood backing glassed in for the lifting ring mounting and look for any rot. Also, check for severely corroded metal components.
Warpman89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warpman89 Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2016 at 10:44pm
Stu
1982 BareFoot Nautique PCM 454 *Under Repair*
'82 BFN
