  New Posts New Posts RSS Feed - 93 sport nautique - squeal near shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: 93 sport nautique - squeal near shaft
    Posted: July-23-2016 at 9:35am
Shane,
To help understand your squeal problem, I thought I'd clarify some boat terminology.
Skag: A slang term for recreational drugs or heroin.
Skeg: A downward facing fin to aid in hull tracking.
Strut: The aft support for the prop shaft.
Cutlass bearing: A bushing in the strut that the prop shaft runs on. Typically a water lubricated rubber, phenolic or plastic.
Gland: The housing where the shaft rope packing is compressed. making a semi watertight seal at the prop shaft. This is typically attached to the log via a short rubber hose.
Log: A attachment point for the shaft gland and where the prop shaft exits the hull. Typical in our boats, this is a bronze casting that's glassed into the hull.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2016 at 6:51am
Shane,
Todd brings up an excellent point that I didn't think of when I responded. The cutlass bearing is water lubricated so it will squeal if dry!
Please clarify what's tight. The gland packing or the cutlass bearing? Where have you been reading to make it tight?
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2016 at 1:11am
Squealing usually comes from bad/overtight packing. Just too clarify, this squealing is when the boat is in the water correct? Struts always squeal out of the water.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2016 at 12:54am
Did you do a complete shaft to strut, log, and engine alignment? Is the gland running hot?
Shook55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shook55 Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2016 at 12:34am
Sounds like the shaft is squeaking where it goes through the skag. I recently replaced the prop shaft and put new bushings in the skag. Why is it squeaking? Feels as if it's too tight but everything I've read said to make it tight. Do I need packing? If so, what?
