  New Posts New Posts RSS Feed - Ignition System
Ignition System
firefighterwes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefighterwes Quote  Post ReplyReply Direct Link To This Post Topic: Ignition System
    Posted: June-23-2006 at 12:49pm
Hey guys I appreciate your feedback alot. Not too mechanically inclined over here.
Thanks Again, and God bless you all
Wes
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 9:11am
you can either get the coversion kit or replace the whole distributer with the latter costing more. With the conversion kit you don't have to get a new coil doesn't hurt but not necessary if the budgets tight. You can get a coil with internal resistor and bypass the ballast resistor, but at the very least if you use the old coil and it has a ballast resistor get a new one. And read the instruction for the kit and use the specified type of coil/ballast resistor.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2006 at 9:29pm
Mine has a Mallory, I just took the points out and replaced it with the electronic, kept the same distributor. I got an Accel coil for heat and vibration which has a gel inside instead of oil, and a set of $90 Accel wires. I didn't have to change the coil or wires. You'll see a difference with the electronic ignition, best $90 I ever spent, alot more response in the throttle.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote firefighterwes Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2006 at 8:23pm
When replacing an older points system with an electronic ignition should I replace the coil alon with plug wires and distributor or just the the distributor??
Thanks,
Wes
Everyone be safe.
