  New Posts New Posts RSS Feed - New Crankshaft damper?
KooK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KooK Quote  Post ReplyReply Direct Link To This Post Topic: New Crankshaft damper?
    Posted: May-05-2017 at 8:32pm
Finally sent it in to Damper Dudes for a repair. The thing came back looking great!
http://imgur.com/a/Bfzue
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 4:13pm
There is a company in Redding CA, might be Anderson or Cottonwood CA. Both are just outside Redding.   Damper Dudes or Damper Doctor. Both companies take your damper and rebuild it and ship it back to you. They have all the popular dampers on the shelf but yours being reverse rotation is special.   They do a very good job and have been in business 25+ years.   Originally there were two partners and they split making the two separate companies. Both do a good job.
Must be a little bit of an echo in here, look back a couple of posts Mark
One thing to watch out for with the aftermarket stuff is the thickness of the balancers and how that affects the alignment of the pulleys.
Unless you get just the right one that'll cross reference to the Ford part number on yours you may have some fun times with alignment
There were a lot of variations on Ford pulleys as far as width and whether or not they had mounting lips for the pulley to mount on.
Not trying to complicate things or disagree with Tim since I think his aftermarket suggestion would be just fine as long as it has the same dimensions.
KenO
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 3:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 1:06pm
Summit racing has 7 dampers listed for a 28oz imbalance 302/351 with a 3-bolt pulley. The cheapest being a $99 Pioneer, which I have heard is a reputable brand. I would not sweat the timing marks, that is the only difference between RH and LH. Just add timing tape or use a dial timing light (TDC is in the same spot).
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 11:15am
An example of the number would be C90E-E1. That happens to be for a normal rotation 351w. from an Indmar 351 so yours will be different.
The PCM part number you need would be R064002 which is no longer available and they tell you to use R064001 which is for normal rotation and then remark the timing graduations for Reverse Rotation.
A R064001 has a Ford casting number of D2TE-C1A
So.....like I said get the number and talk to the damperdudes. in the link in my previous post
Their prices are a lot better than PCM prices anyways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 9:12am
Hi Aaron
Your best bet is to find the part number on your damper.
It'll be either on the front of the damper or on the outer circumference near the timing graduations.
Since it's a reverse rotation engine, the timing graduations will be opposite a normal rotation automotive damper.
Being a 1979 302 if it's original, the crankshaft imbalance is 28.2 oz which calls for a specific damper
And you also probably have 3 bolts holding the lower pulley to the damper unlike lots of automotive 302's with 4 bolts.
All this just means that there are lots of ways to screw up and get the wrong one so get that part number, then you'll probably find it's no longer available but you can get in touch with someplace like     damperdudes.net and they could help you out or rebuild what you have.
KenO
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 8:06am
Aaron,
Search for harmonic balancer and not damper.
KooK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KooK Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 7:18am
1979 Mustang 17 w/ 302 4v
My crankshaft damper (Pulley) looks about 37 years old and the rubber inside seems to be cracking and it's got a bit of wobble to it now. I've been looking online for a new one and cannot seem to find one anywhere, even for a car. I see solid crankshaft pulleys but no actual dampers. Has anybody had to replace this? What did you do/where did you get it?
Thank you!
