1996 super sport gas tank |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
Posted: August-15-2016 at 7:46pm |
That's a rubber mesh pad they lies in the hull of the boat.
gigm94
Newbie Joined: July-22-2016 Location: Texas Status: Offline Points: 11 |
Thanks, where did you get the net in the ski locker? Would love to keep a few things dry in there.
You have to remove the back seat, it just lifts up, then remove the bottom seat frame there are 2 plastic knobs that hold that down them you remove the 2 screws that are to each side of the pylon. Then that whole floor panel from the back to the front of the pylon lifts out. I have a picture of my whole floor out which I can post when I get home.
gigm94
How do I gain access to the tank, specifically the anti siphon valve.
Had a issue and I think it's the anti siphon. Boat is new to me, sat up for several years. changed all fluids, impeller. Ran great first day. Day two ran great started stopped a bunch. Then at end of day decided to open up a little, got over 30mph after a minute or two I noticed the RPM's elevating and dropping back down. Decided to back off and head home. Boat wouldn't restart at dock. Changed fuel filter, FCC was full of fuel when I took it apart. Went back to start and it won't prime. Cant get the a drop of gas into the canister...... Thoughts, I just don't know how to gain access to anti siphon.... Thanks |
