  New Posts New Posts RSS Feed - PCM Transmission for Power Plus V-Drive
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Topic: PCM Transmission for Power Plus V-Drive
    Posted: September-05-2016 at 10:38am
Bump.
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: August-24-2016 at 4:03pm
Sorry Davy. Upon doing some more research, this transmission is, as Tim states, set up for a V-drive - specifically a PCM Power Plus V-drive. I assumed there was an adapter that went along with this for a direct drive set up, but I stand corrected. I will have to repost this correctly.
d4vy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d4vy Quote  Post ReplyReply Direct Link To This Post Posted: August-24-2016 at 11:01am
so im guessing that means its no use to me.. :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2016 at 11:55pm
That tranny is either missing parts or not intended to be used in a direct drive application. It may be for a v-drive.
The 40a 1:1 can be bolted on in place of a 10-17/71c, the dimensions are different from a 10-18:72c.
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2016 at 10:07pm
Davy:
I sent you an email. From my understanding, this 1:1 PCM will work in place of a 1:1 Velvet Drive, however, the damper is different for the PCM..
d4vy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d4vy Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2016 at 2:02pm
hi there, have you still the tranmission for sale? and what are the specifics?
IM looking for a velvet drive 72c 1:1..
if you want to pm or email me davy.mckillen@googlemail.com
cheers
davy
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2016 at 9:39am
Bump
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 2:43pm
Let's try this: $750 for the transmission, $75 for the bell housing, and $100 for the flywheel plus shipping.
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2016 at 10:05pm
New model IRM40-1S 1:1 transmission ( RA157015) that has 0 hours on it. This transmission is set up for use with a 1.48:1 PCM Power Plus V-Drive as seen in the illustration from the PCM manual.
I also have a PCM RA142014 aluminum bell housing for top or bottom mount starter, and a GM 14" Flywheel 93433010N that will work with this set up. They also are new and have never been used.
Bell housing and flywheel are posted separately, unless someone is interested in a package deal. Reduced asking prices: $675 - transmission, $50 - bell housing, and $75 - flywheel, or make me a reasonable offer.
Robb
