  New Posts New Posts RSS Feed - Shifter
Shifter
winniskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Topic: Shifter
    Posted: October-23-2016 at 5:40pm
I looked more closely at the shifter. The one in the thread seems to be a prior generation. I lubricated it liberally and I still feel some grinding. The plates that move the cables are on top of each other. The grinding seems to be coming from the plates, as if a nylon washer or something else is worn out or missing.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2016 at 1:30pm
Originally posted by phatsat67 phatsat67 wrote:
Lube the ends if your cables with WD 40 or a similar mild penetrating lube.
I'd stay away from the WD 40.....works pretty good for loosening things up but after time it gets gummy. There are better products.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2016 at 11:38am
The grinding usually comes from the cables not the Control.
If that doesn't help proceed to the link Pete posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2016 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2016 at 11:49pm
My shifter feels like it is grinding when it is moved into forward and reverse. It is a "CONTROL SINGLE MV TELEFLEX" per Nautique Parts. Any thoughts on the cause? Can I get parts or a rebuild kit for it?
Jim
