  New Posts New Posts RSS Feed - Timing Advance / Performance Question
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Topic: Timing Advance / Performance Question
    Posted: June-29-2006 at 12:12pm
bc is right had same problem with my 68 mustang, i put pertronix and new coil on
but it still wouldnt advance so lubed dist
up and seemed to get good results now it
shoots right out of the water, these ford
motors dont seem to mind some timing.
fredo68
fredo68
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 11:20am
your machnaical advance isn't working and will cause the problems you discribe. You can remove the dist and try and free up the shaft and advance plate so they move freely.
brimeg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brimeg Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 10:28am
This might be a stupid question if so just let me know.
Per the recommendations of 79Nautique and others I have ordered an electronic distributor for my 1967 Mustang with a 302 Ford. Still waiting for the part to arrive and have been playing with the points, etc.
Over the weekend I noticed that the timing (which I set around 10 degrees BTC at idle) does not advance when I go to higher RPM's.
1. This is incorrect right?
2.Would this cause the slow acceleration problem that I have been having.
3. What other running problems would this cause.
4. Is there anything I can do to fix this until the new distributor arrives if it is a problem?
Thanks for the help,
Brian
