  New Posts New Posts RSS Feed - 289 block water channels / flow
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Topic: 289 block water channels / flow
    Posted: October-15-2016 at 4:30pm
<sigh>
OK,   upon further review......
The petcock drain is in a freeze/casting plug.   I honestly cannot say why I left this when I re-did the engine a few years ago. Convenience is the only thing I can think of.   The actual drain plug is forward, as stated by Kevin earlier.    It was a square headed plug, assuming 7/16" or 3/8". Neither of which I own. I put a nice small 12pt on it, but being a 1/4" drive I had no leverage. Then I put a 3/8" drive 12pt on it, and promptly rolled the corners.... I finally ended up getting it out via a bunch of other ill-fitting tools, and techniques. I replaced with a standard 9/16" brass plug like on the other side.
I am questioning actually re-adding the pink stuff after draining.   Not going to do it today, but if there is a consensus that I should, I will do it before we freeze.   What came out of the starboard side was nice and pink.
Kicking myself in the nuts from 6-7 years ago for not replacing the plug then.........
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2016 at 1:18pm
Hey guys
Appreciate the advice. I will either just drain, or do a complete re-do this weekend.   Silly waste of time and pick stuff.   I am going to replace the petcock at the same time.
thanks
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 9:50pm
Originally posted by SNobsessed SNobsessed wrote:
before hard freeze .
Not a hard freeze yet but 1 to 3 inches of snow predicted tonight north of the twin cites. Frost warnings overnight for us in northern Wi.
Mike,
It's always great to hear from you! Yes, just as others have mentioned, get that petcock out to fully drain that side of the block. Chris's drain only idea will work if you don't have the time to completely start over.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 8:36pm
Mike - When you get back to the boat (hopefully before hard freeze) just pull the petcock, let the juice run out, & leave it open for the winter. This is what I have done for the last several years.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 4:49pm
That is the night of Danaween, Alan & Dana's big Halloween Bash, bummer
https://www.facebook.com/events/1676235799357138/
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 4:18pm
Hey Quinner
Fact!      We will be down at Mackey's on 10/22 late night, if you are around.
M
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 2:59pm
What Up Mikey!!
That pink stuff dilutes pretty easily I believe, time for a do over.
Better to sell the farm then to buy the farm!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 2:40pm
Hey dude.
I was in a huge hurry to get it done. Did not have the correct wrench in the boat. We have been working night and day to sell our farm, were leaving on a short vaca the next morning, daylight, etc.
Now that you say that, it was pretty stupid to not just pull the petcock. I was in pure head down, get it done mode.   Dumb.....     It did occur to me to replace it with a plug, which I believe I have anyway, but the hole seemed smaller than the port side at a glance.
I used -50 pink stuff.    I will re do it perhaps this weekend. Plenty of time til the danger zone.
thanks guys. I knew the answer, I guess.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 2:20pm
Hey Mike good to hear from you. Why didn't you just treat the stuck petcock like a plug and remove to drain?
One side will get most of it out but not all. The starboard plug is closer to the front of the engine right? This is in your favor, more water will drain out the port plug if it is closer to the back. The AF you sucked in won't push the water out, it mixes. You've diluted the AF but not enough to hurt it IMO. What is the freeze protection on the AF you started with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 2:19pm
Pulling the port plug won't drain the stbd side of the engine, so you didn't drain the stbd side.
If it was me, I'd pull the petcock and the plug on the other side again and drain it, then redo the pink stuff or leave everything drained..
That way you won't be laying awake on a 20 below Minnesota night wondering if you got the water out the first time when you sucked in the antifreeze,
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2016 at 1:56pm
Hey all,
Have a question regarding the 289 in the Mustang.    I was in a hurry to winterize this year due to some extenuating circumstances.    The PO had a petcock valve in place of the drain plug on the starboard side. I never replaced it as it worked fine. Well, I ran the boat to op temp,   trailered, and went to drain the block, exhaust, blow out the heater hose, etc.   The plug on the port side is just a plug and I drained that. Went to the starboard petcock and it has failed, stuck shut.   I let everything drain from port, blew out the heater, etc.    I then did the bucket pink AF fill and shut her down.
My question is:   is the engine able to completely drain from one side? As mentioned, it was at operating temp 15 minutes before I ran the AF in.   I am making an assumption that even if not, the AF would have gone in, and pushed the water out with the thermostat being warm.   We are quite a ways from freezing here yet, but want to replace the petcock, and re-do it if a few of you think I should.    I am not much of a motor head, and am unclear on the water channel flow / connection within the block.
Thanks, and hope you all had a great season.
Mike
Mike N
1968 Mustang
