1993 Ski Nautique running hot |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
Posted: November-25-2016 at 4:24am |
You can remove the engine cover completely and set it outside the boat for more room.
OverRevLimiter
Newbie Joined: November-21-2016 Location: Winter Haven Status: Offline Points: 5 |
Thanks and further motivation to take on this project which has its awkwardness for tight spaces.
MrMcD
My 95 had an issue with the in line water strainer allowing air to pull into the system.
Make sure the strainer is sealing. New gaskets are available. |
Hollywood
It may not be THE problem but a likely contributor.
OverRevLimiter
That makes sense and I appreciate your explanation. I will proceed and depending on how long that takes, hopefully I will have a favorable fix. Thanks
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2974 |
+1 to what Pete said. I changed out all the hoses on my 1994 SN for just that reason. The HO 351 runs cooler than the other side of the pillow.
No, the logic is they are sucking air. |
OverRevLimiter
I don't mind trying to put on new hoses, as that is pretty easy and considering the present hoses are from December 1992. Not sure how present hoses could be the problem as they don't leak, aren't swollen or showing any cracking. When there was no thermostat the engine ran at 120 degrees. Is your logic that the hoses are somehow obstructing the flow as the suggestion for the overheating?
Hollywood
Probably didn't need a new pump. Probably not corroded either.
Verify temperature. Get all new 1" hoses, they dry out and crack from the clamps. |
OverRevLimiter
I have a 1993 Ski Nautique that in March was running hot and very hot up to 200 degrees after slalom course runs with stops. Strainer checked and clean, changed water pump, new impeller, 143 degree thermostat is new and still running at 170 degrees maxes out at 180 degrees. Someone suggested corrosion in the cooling jacket to the engine block. Is this possible on a 23 year old boat that lives on a fresh water lake? If possible how to test and how to fix?
Appreciate your help. |
