  New Posts New Posts RSS Feed - Dash gauges pegging and breakers not working
velde99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote velde99 Quote  Post ReplyReply Direct Link To This Post Topic: Dash gauges pegging and breakers not working
    Posted: February-10-2017 at 3:51am
geecee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2017 at 3:13am
Sounds like a short to ground, id look for any loose connections on your dash pod for a start, could be a small broken wire or a loose connection touching somewhere it should.
Id say it may be main supply coming from your ignition side if all gauges are pegging, so start there and work through those guages
1983 Ski Nautique '2001'
-Chev 350 Mercruiser
-Custom Wake Tower
-Custom Interior
Post Options Post Options   Thanks (0) Thanks(0)   Quote velde99 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2017 at 11:01pm
I figured it was electrical. Any thoughts on solving that issue? Where to start. Is pod grounded?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2017 at 10:25pm
Sounds electrical
Post Options Post Options   Thanks (0) Thanks(0)   Quote velde99 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2017 at 10:00pm
I am having trouble with a 1991. The gauges peg when I turn the key to the on position. Also the lower right panel with all the push button beaker switches isn't working. The only button that works on the lower panel is the ignition switch. Everything else is dead- blower-lights-pump-accesories. What could be wrong? Thanks for any help!
