  New Posts New Posts RSS Feed - correct prop for 2004 super air
04air View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 04air Quote  Post ReplyReply Direct Link To This Post Topic: correct prop for 2004 super air
    Posted: July-05-2006 at 4:23pm
Yeah it does have the 330hp and ballast tanks.I will check out the sight.Thanks
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2006 at 4:17pm
04. There has been a lot of discussion about this particular boat/prop combo on planetnautique.com. I know the preferred prop is an acme, but I believe there are two models of preference depending upon how much weight you run in the boat. Also depends upon which motor you have, thought I suspect you have the 330HP Chevy. You might do a search on that sight as well. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote 04air Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2006 at 3:58pm
What is the correct prop for a 2004 210 super air team edition
