1969 Correct Craft SN |
Duane in Indy
Posted: April-02-2017 at 12:10pm |
Chrysler 318 Long Block (with heads) Marine ENGINE 0 Hours L@@K ! 250 HP Short block .030 over OMC,Crusader,Volvo NO CORE eBay item number:272608894799 I don't know Mopars so you need to make sure of compatibility. This guys ad seems like he is knowledgeable about marine engines. I would give him a call and find out if it will work (rotation, ect.) Sounds hard to beat the $$ and get a warranty. JMO Duane |
1978 Mustang (modified) |
Guests
Guest |
i probably should have looked there
Duane in Indy
Dodge magnum 318 block eBay item number:252799897603 $130 OBO eBay has many edit: another one in NY for $85 |
Guests
Guest |
How hard are 318 Chryslers to find these days?
trice
Groupie Joined: September-26-2016 Location: Columbus, Ohio Status: Offline Points: 87 |
87 SN
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
That Ford block is so rusty that the distributor hole seems to have relocated itself to the back of the engine block just like let's say a 318 Chrysler |
Looks like the following is confirmed!!
Guests
Guest |
Thanks Pete will do. Ill go ahead and post this over in the general section as well.
fgroce
Senior Member Joined: July-05-2016 Location: Georgia Status: Offline Points: 350 |
Little wd40 wipe out the bores and should be good to go!
FGroce
88 Ski Nautique For 28 years Now 2002 Ski Nautique |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21184 |
Lol
Guests
Guest |
Disregard found a pic. Here is the current condition of engine |
Note, Gary is measuring between bolt holes! |
Guests
Guest |
thanks Gary ill check it out when I get home
Brian,
Keep us posted with the progress in the fall. You should post the find in the 1st gen SN roster in the general section of the forum. Sounds like you may need an engine and trans. If you go looking, make sure it's a RR and not a standard. With the narrow hull of the 1st gen, a standard rotation will make a BIG difference that I don't feel you would be happy with. Again, great find!! |
Looks like a great project. Just measure across your intake manifold 302 is first picture,351 is second-
Guests
Guest |
no im not sure if its a 302 I was assuming. It just looked small like my mustang, wasn't sure.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
The "Hotfoot" is a very cool junkyard find!
Yes two completely different boats. You sure it's a 302?
Guests
Guest |
Ill gut it so it can dry and start a restore in the fall. I don't think the gel can be saved so ill have to approach that at a later time. The 302 is stripped and rusted and supposedly cracked. Is there a difference in the hull design other than the splash guard from the 69' mustang and SN?
Brian,
You're probably correct with the year or very close. Nice find in the junk yard! What are your plans? Is there an engine under the dog house? |
Guests
Guest |
Picked my new project up today! I noticed there isn't much in the reference section for 1969. I believe this is a 1969 based on windshield, splash guard and vents. I have no other information on this boat as It was in a junkyard.
