  New Posts New Posts RSS Feed - Gazoline smell at the rear of the boat
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Topic: Gazoline smell at the rear of the boat
    Posted: April-07-2017 at 1:11pm
Serge,
   this thread and your other carb thread are very similar, so I think you should keep all the Information in one thread.   It will help those trying to help you, so that they understand the whole scope of the issue you are having.
That said, the floats are inside the fuel bowl of the carburetor.   you need to bend the tab on the float so that the needle and seat shuts off the incoming fuel at a certain float level.    I would recommend that you have someone familiar with carburetors help you at this point. While I don't doubt your ability to tear down and re-assemble, you have missed some critical steps in the carb rebuild process....   you need someone to help you understand the instructions and get this correct.    it sounds like you may be on the fast track to an engine fire, or filling your oil sump with gasoline..
wakespirit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2017 at 5:31am
what is the way to adjust fuel float level in the carb ? never done this.
Any steps by steps procedure or pictures, video,... ?
If I re open the carb to access the fuel level do I have to change the gasket again by a new one event if it is already new ?
regards
serge
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2017 at 9:28pm
Also make sure choke is opening all the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2017 at 6:02pm
sounds like the carburetor is not adjusted correctly.    float levels are very particular and can cause the boat to run very rich if poorly adjusted.   I would start by re-checking float levels, and adjusting the idle mixture (using a vacuum gauge) to get the carb set up correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2017 at 4:28pm
Dear all,
Last year I have repare my carb of my correct craft by changing all part from a repair kit.
After this and go on the water, When I am and the rea of the boat while fitting my skis, quite big a mount of brown color smoke and gazoline smell.
Any idea what could be come from ?
Is there anything to do from my repare or simply adjustment ?
Thanks for help
regards
serge
