  New Posts New Posts RSS Feed - Proper operating temp
Netdewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Topic: Proper operating temp
    Posted: July-03-2017 at 9:26pm
Generally I reverse, but it doesn't always work.
1989 Ski Nautique 2001, 940 hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2017 at 6:32pm
Sometimes you can clear weeds just by backing up quickly or spinning a sharp turn around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2017 at 2:51pm
An update - I let the boat sit for the night and cleaned the strainer the next morning. Took it out and dove under to check for weeds on the intake. I made sure all was clear and it has run at or below 160 degrees the last few days. I am continuing to make a habit of watching the engine temp.
My dad's cabin is on a small harbor totally choked with weeds, so I have to make sure to clean them off every time I leave.
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2017 at 9:39pm
My 1995 SN does not have a sea cock.
Well, the memory fades as the years add up. Perhaps it was when we developed the SN 200 that Uncle Coast Guard made that ruling.
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2017 at 5:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 10:34pm
For clarification on seacocks, the boats prior to about 1990 didn't have them except for the saltwater boats. (Fish Nautique and San Juan)   About that time the USCG put a rule in place that all boats 20' or over had to have seacocks, Since the SN was the only boat we made under 20" at the time, it was decided that it would be less confusing to just put it on all models.
"Art"
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 2:03pm
Don't worry about the seacock, our boats typically don't have them. The strainer will just unscrew. Be careful not to lose the circular gasket when you're dumping out any debris. The little tubular screen should pop out with a little coaxing. But no need to pop it out if it's not dirty.
As the others said, the strainer should be above the water line if it's still in its original location. Some water will probably come out as you unscrew, but it should just be what's in there already. If it keeps coming (unlikely) then quickly screw it back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:25pm
It is above water line. I tried youtubing and saw some comments about a "seacock" valve that needs to be shut off. Must be for big boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:20pm
Nate,
The strainer should be mounted above the water line as well but do check to make sure a PO hasn't moved it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:17pm
Yes, I know that it should not be run out of water. I've been careful to ask a lot of those questions, I just don't know what parts are where and what will happen when I remove them.
The impeller is inside the pump, after the strainer, bolted to the left hand (port) side of the engine, correct?
Can I open the stainer and or mess with the pump without flooding the boat? It's in the water and I did not bring my "toilet plunger".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:11pm
Nate, One more thing to keep in mind is the rubber impeller is water lubricated so you do not what to run the engine with the boat out of the water without hooking it up the garden hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:08pm
Originally posted by Netdewt Netdewt wrote:
I don't see any sort of valve to close, what will keep water from coming in when removing any of these parts?
The RWP is above the water line so you can R&R the impeller with the boat in the water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:06pm
MACS81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACS81SN Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 12:47pm
Rwp = raw water pump
1999 -SN - 502 Python
1981 - SN Owned 33 years - Sold
1968 - Mustang - Sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 12:39pm
Yeah, I know impellers need to be closely watched. Is it an easy DIY job? I want to check for weeds this morning before I spend money at the cabin and add stress to the weekend.
I wish I did, but I'm not sure what "rwp" means! Lots to learn...
bb12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bb12 Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 12:13pm
Pop the rwp off and take a look. It might need a fresh impeller...first thing I did when I bought my boat was change the impeller...its cheap insurance.
You can check the intake in the water, you'll just need some goggles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 11:54am
I have not changed the impeller. Purchased last year and previous owner said it was changed recently. But I'd say 2-3 years old.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 9:58am
Have you changed the impeller lately? Might just be a coincidence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 2:22am
Agh. It's carbeurated.
Intake can really only be checked out of water, right?
bb12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bb12 Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 1:02am
Yes, that can happen. Check the intake, strainer and tranny cooler for weeds/debris.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 12:35am
For carbureted engines 140 is the standard Thermostat Temp. For Fuel Injected Engines in boats the temp is 160. 180 tells you there is an issue to fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Netdewt Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2017 at 12:11am
What is the proper operating temperature for my 89 SN? I went through a ton of weeds (par for the course this time of year) and started to wonder if the intake is plugged. Does that happen? It was running at about 180 just now. I think 160 is pretty typical after an initial warmup.
