  New Posts New Posts RSS Feed - Rudder install question
steinjt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steinjt Quote  Post ReplyReply Direct Link To This Post Topic: Rudder install question
    Posted: July-05-2017 at 2:40pm
yep. washers up top made sense, just wasn't sure why there'd be one underneath. gonna go without one underneath.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2017 at 2:04pm
Ha Jody is right.. someone could have been trying to take the vertical slop out of the rudder. I would recommend doing so on the top side of the shaft if needed rather than underneath where it will change water flow (and fall off upon rudder removal).
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2017 at 1:56pm
Have seen brass washers installed between rudder and port! not that that is correct but some of these guy's throughout the years are pretty inventive!
Would look close and make sure that the Brass washer on top between the tiller arm and packing nutI
I am sure I have not seen it all !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steinjt Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2017 at 10:06pm
Thank you. Just the answer I was hoping for but my buddy swore something dropped when the rudder came out and he was sure it was a washer. In looking at it I didn't understand what its purpose would be and of course I couldn't find a diagram.
Thanks again.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2017 at 10:03pm
There should be nothing between the rudder and port/hull on the underside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steinjt Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2017 at 9:36pm
Had to remove my rudder while boat was on the lift in the boat house and my buddy that was in the water catching it dropped a washer that was between the rudder and the hull. He didn't get a good look at it as it sank to the depths so couldn't really describe to me what I need to buy to replace it. Does anyone know the size of that washer (I.D., O.D., material and thickness) or at least know the diameter of the rudder's shaft? It's an 89 Sport.
Thanks
