Broken prop shaft |
Post Reply | Page 12> |
Author | ||
Duane in Indy
Posted: July-07-2017 at 8:55pm |
Don't forget-----use a brass nut
1978 Mustang (modified) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11059 |
The ones I've seen had splines on both ends, but I don't know if they all are |
And please, anti seize on the nut threads. |
Duane in Indy
More than likely a 10" crescent and a piece of pipe |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
Splines on both ends seems like a winner to me. There must be some logical reason why the keyway is used instead of splines.
From wiki Splines are ridges or teeth on a drive shaft that mesh with grooves in a mating piece and transfer torque to it, maintaining the angular correspondence between them. ... An alternative to splines is a keyway and key, though splines provide a longer fatigue life. |
phatsat67
Ken, is that coupler side splined too? MC has used splines for propellers for a while now.
Riley
Just curious, is everyone that has bought one of these using a torque wrench to lock the shaft into the taper? Does that matter?
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5778 |
Not to beat this to death but I stumbled onto the patent info, regarding the coupler taper it appears the steep taper was deliberate to facilitate "easy" removal and decrease man hours required.
From the patent application "A coupling receives a steeply tapered end of a propellor shaft and is secured thereto with a lock nut held in place with a set screw. A housing taper is steeper than known locking tapers to facilitate housing removal. The housing is internally threaded to receive an extractor element which, after lock nut removal, is screwed into the housing for abutment with the end of the propellor shaft with continued advancement of the extractor element resulting in housing separation from the shaft." full link |
A Mastercraft splined propshaft. Picture courtesy of Ebay Straight splines, no puller required. Just like the 6 bazillion outboards of all sizes floating around out there. |
tryathlete
I used to be in the steering wheel business. We sold steering wheels that fit onto splines and tapered steering column shafts with a hub mated to the wheel with Huck fasteners. Never had issues with fit.
Doesn't Mastercraft use splines/taper on their propellor to shaft engagement? |
Duane in Indy
Yes splines are expensive to cut. You get one company making shafts and another making couplings and they don't match up perfectly. No way to correct splined setups either.
Also 1 failure per several thousand doesn't warrant change. Get a donor shaft and machine it to fit. Cheap easy fix. Or see if you can get any warranty help from the original maker. I like the "Beer Engineered" method listed earlier. Now if we could just get Pete down to interject his thoughts next week. |
tryathlete
As a ranking ameteur who never even aligned a prop shaft, let alone replace one with an ARE, but who does have some mechanical aptitude, is there a reason why splines aren't used in conjunction with the taper instead of a keyway? Square corners are bad enough but reduction in cross-section to 7/8" seems to point to using a larger shaft diameter if the keyway is going to stay. I know that's impractical at this point.
Splines sure don't fail like that keyway. They're more expensive to machine but there must be another reason that I'm missing |
phatsat67
Alan, I think the beers next weekend will help get it figured out. Let's solve some world problems as well. See you Saturday am.
HW. I will pack brackets for Duane. |
MechGaT
Senior Member Joined: March-09-2015 Location: Chattanooga Status: Offline Points: 271 |
As I am sure several know, but some may not, the ripples indicate crack growth. The closer ones point to where it started and the ones farther apart indicate where it was speeding up due to the reduced cross section. The big chunk in the middle is where it finally broke. We have known for some time that sharp corners are bad, but surprisingly they still get left. That was my first thought.
'92 Sport Nautique
MrMcD
They learned years ago that square corners make weak spots in machined parts.
Engine Crankshafts have rounded corners or fillets as they call them. This really increased the strength of crankshafts when they figured that out. Even Pistons have slightly rounded corners behind the piston ring grooves. Maybe the ARE folks just did not have that experience. We learn something every day. |
Riley
Me too. We've got about 50 hours on ours. I'd be pretty disappointed if it broke. If I remember right, they required the nut be torqued to 60 lbs? |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
I had a woodruff key in a boat I took apart 5 years ago.
The coupler I got this year from Elbert's had a square key. No pin Joe. |
MrMcD
I installed a new ARE shaft, now has 50 hours on it but this thread has me concerned.
I know I lapped the prop well but do not remember lapping the coupler end. Maybe time to tackle that job? Mine was installed in 2014 is that the new or old version? Sorry about your troubles but thanks for pointing out an issue to be addressed! Mark |
81nautique
I do the same Zach and didn't measure any discrepancies. That doesn't mean it stayed that way though if the shaft didn't seat properly. probably my bad for not being more diligent with checking the fit. Measuring from the depth of the keyway that leaves the shaft less than .750" . there's a lot of material hogged out of there. I'll be meeting Duane at lake James next week so I think I'll bring the new and broken parts with so we can have a beer and think it through. If we decide I'd be better off sending the new shaft back for the later revised version so be it. I want to get the boat back together asap and it might cost me a few extra weeks to have a new coupler machined but would be worth it in the end. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
I've never thought about it that way, but really would make sense. When you add up the cost of a shaft, lost time, and possible cost of a prop, it would be good insurance against alignment issues. |
Duane in Indy
FWIW, Kevins prop shaft/coupler assy measured with in .001 square after assembling. I cut the taper on the shaft. When I blued it up I could see no reason to lap it You could drop it onto the shaft and the coupling would lock up without any extra effort. He supplied the shaft and coupling; and I provided the machine work.
phatsat67
Dang Alan, that sucks. I guess I was too hard on the throttle at Quinners. (thanks for letting me run it around again).
Joe is the shaft expert. Kev has had Duane in indy make some pretty neat stuff all around. Would be a great option if something else breaks. Do you have a good shop locally that could machine lap the coupler than face it after it was installed on the shaft? I've always wondered how far off the coupler faces are. I try and do my alignment by moving the shaft into all 4 possible positions once my initial alignment is set to check coupler face and shaft runout. Hopefully this doesn't break. We have put about 200 hours on my brothers ARE in the 89. Extra 1.23 torque and slightly less HP than the Hemi. |
I sure feel a proper fitting taper would help the 19 of the 20? Then, if not, I'd say 19 of those customers should not be installing their own shafts! |
63 Skier
Pete, if they sold those shafts without a key people would be spinning them in the taper more often than not. I'd guess that 1 in 20 of their customers would take the time to lap the shaft into the taper, maybe less. I think it's just practical for inboard shafts to have a key, but some engineering has to be put into the taper and key design, as it sounds like Joe indicated to one of the suppliers.
With them adding a key and keyway, they obviously don't trust their skills at making tapers and it showed when I've lapped in their tapers!! There shouldn't be any key!!
JoeinNY
Well that makes sense, glad they could learn from my field test results over the last 5 years. Do they put a pin in the key to keep it from sliding like General Propeller? |
Hollywood
If you're rotating the shaft during your alignment then you'd find the coupler face is not square.
The keyway on the new Elbert's coupler is long and square (1/4"?) just like the prop end. |
81nautique
I agree the keyway seems far too deep and is exactly where mine broke. I'd hate to think it couldn't handle a sub 300 hp motor but the fact that they have changed their taper means something. I wonder if the keyway has changed as well. If it wasn't July I would take more time and go a different route. I'm probably setting myself up for another hit, Guess I'll look into general prop over the winter. |
JoeinNY
After breaking a few of them ARE’s –that I had custom ordered from the strongest shaft material they could get, always at the coupler, always starting at the really deep keyway I have given up on them. That taper is short, and that keyway is deep. Lapping it will help, getting it square after that will also help, but if it happens again general propeller will likely make you a dual taper shaft with a longer shallower taper on the coupling side and a better key system. It wasn’t cheap but it was cheaper than the ARE – The 3 broken ARE shafts and 3 bent up 1492 Acme’s off my 83 - are about the ugliest waste of 3500 bucks I have had in my long storied history of throwing money into boats. Might be a good project for Duane in Indy.
81nautique
So after some thought I'm going to lap the new shaft to the coupler and then put it on some blocks and check the coupler face runout before installing it. I'll have it machined if need be. Realign it and then check it again with the boat in the water and see where it is.
Pete, to your comment, I was told yesterday that ARE did change the taper of the coupler end on their newer shafts. he didn't say why, only that it was an improvement. I had to stay with the old taper because the coupler was custom made to the old taper spec and I'd have to pull the mating piece off the transmission and send it to them again and I don't want to loose the time and money it cost for a new one. I'll get it lined up perfect and take my chances. It should be fine if I make sure it's trued up correctly. |
