fuse box |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Posted: August-20-2017 at 6:01pm |
This sounds like it has keyless ignition and them newfangled gauges that I know nothing about except they were troublesome in some model years right around yours
Duane in Indy
Try running a separate ground wire to them from the battery and also separate positive wire also. Alligator clip jumpers are handy here
1978 Mustang (modified) |
footskier
Newbie Joined: August-20-2017 Location: angola IN Status: Offline Points: 4 |
completely dead, no lights or gauges, when just turning on the ignition they don't go through test phase, no gauges, no tach, no speedo and yes I have a volt meter
footskier
seems to have lights working but not on gauges and blower works... they just went out and all fuses are good... battery good and 30amp fuse on battery is good. boat starts but no gauges work
No power or not reading right ? |
James,
Welcome to CCfan. Tell us more about the boat and pictures are always welcomed. Regarding the gauges, have you done any testing? Do you have a VOM (volt Ohm meter)? |
footskier
2003 196 looking for for why all gauges are off...
