87 Centurion Trasmission |
Timr71
Groupie Joined: March-28-2016 Location: Alabama Status: Offline Points: 81 |
Posted: August-23-2017 at 12:19am |
Here's that rebuild thread from over on TeamTalk:
https://www.mastercraft.com/teamtalk/showthread.php?t=53874 |
wardameagle1
Newbie Joined: August-20-2017 Location: Jeadlanx Status: Offline Points: 7 |
Tenfo. Thanks for the advice.
Duane in Indy
I bought my kit (stage 2) from WORLDWIDEPARTSOUTLET off of e-bay. Order a new damper flex plate while you are at it. I highly recommend NOT using the front pump seal "ALTO #023420" that comes in the kit. It is entirely encased in neoprene type coating and will not stay in the bore as well as a steel encased seal. Replacement is easy to come by. Just get same ID and OD and thickness as the Alto. Master Craft site has a good rebuild pictorial you can view. Also recommend getting a rebuild manual. Special tool set for the Velvet is handy but not a have to have set to rebuild. |
1978 Mustang (modified) |
wardameagle1
That's what I think im gone do. Where do yall recommend getting a rebuild kit from
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
tryathlete
If you're in a hurry, just buy the rebuild kit and go all the way through it--bearings, seals, friction material, or if you want to take a few more days and take a risk on someone else's opinion of what a rebuild is-- ( best to do your own work if you can--like anyone here who has done this or rebuilt their stringers-- 😷)
[http://m.ebay.com/itm/Velvet-Drive-Transmission-Let-us-rebuild-yours-495-parts-and-shipping-/162561641949?_trkparms=aid%253D222007%2526algo%253DSIM.MBE%2526ao%253D1%2526asc%253D20150519202348%2526meid%253D18532d8e1ae64df5959a4af8aadbe176%2526pid%253D100408%2526rk%253D1%2526rkt%253D25%2526sd%253D152594876165&_trksid=p2056116.c100408.m2460] |
GottaSki
Thats a bummer
Now the shifter is just a spool valve, nothing mechanical. You can try to take it out and inspect the passages and orings just as easily if on the bench. Consider free it it up sooner then later, having seen water |
River Rat to Mole |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
You're a mechanic, tear into that thing, you've got nothing to lose
A manual is in the reference section and parts are easy to find. |
wardameagle1
I'm a mechanic. Also I checked it a while ago. Yes the shaft spins fairly easy. I can hear the transmission ratcheting like a bearing went out. Also checked my shifter. It will only go fwd so I guess it's broke now. Geez.
Duane in Indy
Time for a tear down and autopsy Sounds like the clutches have fried. Reverse the same problem also??
What level of mechanical ability are you?? Or do you have a friend/mechanic that could help you. Several of us have performed a rebuild successfully. |
wardameagle1
Last weekend it was Running perfect when it just quit pulling and started squeeling. That's when I figured out the oil cooler was bad
wardameagle1
I was in the water yesterday. I had got all the water out of it last week. And put new transmission fluid in it. It wouldn't go into gear and was still squeeling.
I was wondering that too but figured I asked enough questions for one post.
I always thought of that as a growl or groan,with a dry cutlass bearing but who knows |
And I'm wondering Ken if he's running it on the trailer and it's the cutlass squealing? If it was on the trailer I'd wet it down,if tried in the water I'd disconnect the shaft.
Do you mean the shifter handle up by the driver's seat won't put it in gear?
If that's the case unhook the linkage at the transmission and try to shift from back there and see what happens. I never heard of anybody doing a diesel fluid flush on a transmission before, hopefully you just have regular transmission fluid and no diesel fuel in it now. How long did you run it with water in the fluid? If it filled it up that's a lot of water and maybe you ruined a bearing or 2 or 3. With the engine OFF and in neutral how does the shaft turn by hand? Easily or does it squeal and groan and turn hard?. |
wardameagle1
Having transmission trouble. I just bought this ole boat. It has a 351 engine and a velvet drive transmission. The oil cooler went out and it filled the transmission up with water. I think it ruined it. I flushed it with diesel and new fluid. But it's still squeling and now the shifter won't go into gear. Help please. Lol
