  New Posts New Posts RSS Feed - '86 Ski Nautique Resto
geecee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Topic: '86 Ski Nautique Resto
    Posted: September-19-2017 at 9:12am
how are you getting on? if I get my engine out for rebuild I will be pulling the floor.
Hoping desperately that I don't need to do stringers, but expecting that I will probably have to, I love to follow progress on these.
1983 Ski Nautique '2001'
-Chev 350 Mercruiser
-Custom Wake Tower
-Custom Interior
MikeEby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeEby Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 11:45pm
Originally posted by Duane in Indy Duane in Indy wrote:
Mike, Nice documentation   Pictures will help you reassemble things a lot.
My recommendations now would be to "chart" all the stringer dimensions. I laid a 2 X 6 on edge from one gunnel to the other, starting from the stern as far back as I could go and still drop a tape measure down vertically to the stringers. That was my starting or "datum"point. Then I moved the board toward the bow in 12 inch increments and documented each move vertically to each stringer.
I did that but not at that frequency. I'm at the point now I can go back and fill in the blanks. Thanks!
Leaving small portions of fibre glass where the stringers were will help you set the new ones in the exact place in the hull also. Make the fit between the hull and stringer bottom as good as you can get but don't worry about the top of it yet. Now you glass them in at the bottom.   Next I recreated the vertical dimensions with marks on the new stringers vertically down from the same board.   Connect the dots and that will be a saw line for the floor to set on. This method worked for me to recreate what I had.
Sorry for the long thread.   This is just one of many methods that will work.
That make sense, I did see the tip on leaving small area of the original fillet to use as a guide for the new stringer, Not exactly sure of what material to use for the stringers yet. Don't worry about the length of the post, I need all the help I can get.
Originally posted by NCH20SKIER NCH20SKIER wrote:
Welcome and keep the pictures coming
I will for sure, I'm hosting the pictures on my own server so as long as I'm around (Alive) :) the pictures will be there. We lost a ton of information when Photobucket changed their terms.
Originally posted by gun-driver gun-driver wrote:
My 85 had a block left in the right rear under the foam also.
As Duane's method worked for him I found it easier to just do one side at a time. That did two things
1) it helped maintained the hull shape/integrity
2) I was able to just mirror the existing side with the new side by simply using a level.
You can go to my photobucket to see the pictures of my resto
Yes the one side at a time has merit for sure I can see that, I braced the hull in what some might think is unconventional, I'll post some picture soon on that. A backup plan is always a good thing, Once they are out you can't hardly go back. Kind amazing the lack of wrapping of the glass that CC did on the secondaries. It was probably to keep consistency in the floor still it looks like there was nothing, bare wood near the top.
Correct me if I'm wrong but I think you did your rebuild without foam? Which is very interesting. Does the boat seem as solid without the foam?
I wouldn't be surprised if water as been in the foam since the early 1990's because I started noticing small hairline cracks in the gel coat just below the waterline, First on the port side then years later on the starboard. My guess was now after seeing how much water was in the foam it was freezing and expanding during storage causing the gel coat to crack. The glass looks solid but I should probably lay a layer or two on the inside in that area just to be sure, more grinding ARG!
Has foam technology change since the eighties where it's not as prone to absorb water? I do understand that epoxy resin forms a better barrier against moisture then polyester resin used back then, never the less it's a boat some water will get in somehow. The idea of hauling around a several hundred pounds of water is not appealing.
I think I recall seeing your pictures and you had some very elaborate floor bracing to support the floor in lieu the foam. If there was a way to see those again I would gladly host them on my server.
I also understand the use of foam for flotation and safety, not a major concern for me, I was raised around wood inboards, ZERO FOAM in those babies! My dad and uncle had a few wood Century inboards between them. In fact before the Century my uncle bought an Atom skier new, I think he picked it up at the old Pine Castle factory in the fifties. He outgrew the Atom quickly and moved into a Century Coronado. Talk about an extreme upgrade! The Coronado was too big and obnoxious even for him so he settle in with a nice 16' Century Resorter he had for many years until the first glass Century Resorter came around in 1968 or so. Strictly an inboard runabout is my taste, I guy I work with was looking at bow rider clamp-ons and asked me for advice on boats. He was put off when I said...hum... a bow rider? Do you let your kids ride around on the hood of your car? And what the heck is that thing hanging on the transom for?
Mike,
The block of scrap in the boat was CC's method of cost reduction back then since it reduced their dumpster pick ups.
Looking good and yes, keep the pictures coming.
Or maybe Correct Craft was being environmentally conscious even in the eighties by not using the land fill. Or better yet one of their worker was thinking, lets mess with this guy's brain in the year 2017.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 2:00pm
Mike,
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 10:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 8:26am
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 7:05am
My recommendations now would be to "chart" all the stringer dimensions. I laid a 2 X 6 on edge from one gunnel to the other, starting from the stern as far back as I could go and still drop a tape measure down vertically to the stringers. That was my starting or "datum"point. Then I moved the board toward the bow in 12 inch increments and documented each move vertically to each stringer. (measuring from the stringer top to the bottom of the board) .This will generate a blue print to go back to when you reinstall each stringer. The only portion that needs to be really accurate is where the engine sets. Also document the widths of the stringers. Leaving small portions of fibre glass where the stringers were will help you set the new ones in the exact place in the hull also. Make the fit between the hull and stringer bottom as good as you can get but don't worry about the top of it yet. Now you glass them in at the bottom.   Next I recreated the vertical dimensions with marks on the new stringers vertically down from the same board.   Connect the dots and that will be a saw line for the floor to set on. This method worked for me to recreate what I had.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeEby Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 1:01am
Finished the weekend and starting this thread, Here were we are at right now, All the nasty foam is gone!! All the floor is out including the bulkhead on the drivers side,
The main stringers are not real bad but will be replaced, the secondaries for the most part are mush. Next weekend I'll start tearing into to those.
This has been mentioned as a "Repair" in several threads, I can state that the boat has never been repaired were this so called "Repair" appears. The only thing I can figure is Correct Craft mounts the pylon pin after the hull is finished, Perhaps it was done in the later assembly process when the engine cradle was set.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeEby Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 12:48am
Sunday was spend getting the foam out of the port side and removing the battery box and remaining floor up to the drivers side bulkhead.
Popping the foam out which came very easily by using a flat spade type shovel, someone here recommended. On removal of the last piece on the port side I found something interesting, what appeared to be a chunk of wood on the bottom of the hull buried in foam. Does this perform any function or was one the worker just lazy and left a chuck of wood about 6" square in the bottom when they were foaming the boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeEby Quote  Post ReplyReply Direct Link To This Post Posted: September-05-2017 at 12:38am
I've been lurking here for several years, joined a month or so ago and this is my first thread. I'm the original owner of a 1986 Soft Silver and Burgundy Ski Nautique that has served me well for 31 years.
The old girl was getting pretty rough and I knew it was time to jump in with both feet or move on. Looking at new boats they were prices way out of my price range, Looking at a lot of used boats that I could afford I came to the conclusion in a few years they would be no better then mine.
I'm pretty mechanically inclined and do most if not all repairs to just about everything I own. So here we are, gutting the boat was pretty straight forward and that where this thread begins.
Unbolting and removing the engine, interior parts, seat, carpet, wiring dash and bracing the hull were time consuming but not difficult.
This weekend I started the heavy lifting, Cutting into the floor to start the stringer/floor job.
Here are a few shots of what I got done this weekend,
Started at the rear of the boat with a diamond blade in circular saw. set the depth so it would cut only though the glass starting at the stern, Someone here recommend using the guide to keep the from gutting into the hull. This tip worked very well. On areas were the circular could not reach a 4-1/2" angle grinder with a Diamond blade supplemented the floor removal.
This is what I found under the driver seat. Soaked foam and rotted wood was EVERYWHERE.
This was were I left it after day one. All the foam out on the starboard side and the floor glass removed on the port side.
Out of curiosity I weight a chunk of foam, A 24" long piece taking out near the stern weight 19 lb. I have to estimate the boat has several hundred pounds of water soaked foam.
