  New Posts New Posts RSS Feed - could have been worse
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: could have been worse
    Posted: January-10-2018 at 7:35pm
Larry,
I too like the epoxy idea. You can get one of the epoxy duplex syringes at the hardware store. It does all the mixing for you.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2018 at 7:16pm
FLEX SEAL!
just kidding, epoxy is what I would reach for. And dont forget to tint it to match the glaze.. :)
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2018 at 3:32pm
I wouldn't use 5200 personally - if it is very tight break I would use super glue (cyanoacrylate). If it was a bit off I would use epoxy. 5200 might work just fine truthfully but generally gives up some adhesion to allow some flex vs an epoxy in this case you don't need the flex.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2018 at 1:15pm
5200 ought to work. Most importantly, did you go the distance and pour anti freeze into the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2018 at 1:10pm
Better than an engine block.
As you may have heard, we had quite a cold snap in NC recently, single digits and teens. I forgot one little bit of maintenance, to empty the water out of a stoneware fountain we have on our deck. Again, not as bad as an engine block, but I'm not sure my wife would feel the same way. Since it is just a split or two and not crumbled I think it can be fixed, but I dont know what to use. I was thinking 3M 5200, but not sure it would adhere. Any other thoughts? Pete????
