High RPM Problems |
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
Posted: May-28-2004 at 11:57pm |
I don't mean to be cruel, but, lately I've been seeing a lot of posts about ford r.p.m. problems. I feel like I'm preaching when I say, check ignition valve timing, and cam lift. Springs can be weak, and cause problems, a lobe on the cam can wear through the hardened portion of the lobe and not open a valve. Hydraulic valve train is not adjustable like solid lift is. Like it's been said before in this forum, all an engine needs is: the correct amount of gas, and a good spark. All in the right time, of course. Suck, Squeeze, Bang, Blow.
bcjones
Newbie Joined: May-28-2004 Location: United States Status: Offline Points: 4 |
I've been having problems with my '79 351W R at RPM range above 3200. The engine was just rebuilt and has the following new parts; Pertonix ignition, coil, distributor, carb, fuel pump, spark plugs and wires. It runs great at an idle and has terrific hole shot but will cut out at higher RPM. I thought it was a carburator problem so I replaced it with my old one and the same problem occured. Any advice?
79CC
