Universal Sabre |
Author | ||
Posted: April-02-2018 at 1:31pm |
Bryan,
The B/W 70 bolts up to a bell housing with the SAE trans flange but you need the bell housing to match the 225 engine you have. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
Bryan, there is a bellhousing that fits a Buick 225 and also fits a BW Velvet 70C. In your case you have a bellhousing that fits the 225 but is made to bolt up to your I/O. So, you can look for the bellhousing that can let you use the 225 and your current tranny, or you can rebuild the 198. Once you see if the bh is even available, and if so what it costs, you'll be able to decide pretty easily I think.
B4nier
Newbie Joined: April-01-2018 Location: N.H Status: Offline Points: 11 |
I guess I’m confused I keep getting told that the bell housings are interchangeable from the transmission is what I understood. But I guess I’m not understanding it right
I thought you wanted to use the trans you have??
B4nier
Great information, thanks a lot. I will start looking
For rebuild parts, and get some pictures out as soon As I get a chance. If I decide to stay with the 225, where Would be a good place to look for a transmission? |
Bryan,
The way to make it work is, as mentioned, get a bell housing to match the 225 with a SAE to match the trans or, as Ken mentioned rebuild the original engine. As Marty mentions, bell housings do not interchange on different blocks. The B/W Velvet drive was the most popular trans but there were others like Paragon and even the Dearbomatic made by Ford. For pictures, click the full reply icon (diagonal arrow in box) above or go to "post" reply and not the "quick". Then click on the tree icon with the up arrow. BTW, for parts, maybe the difficulty you are having finding them is because you've been looking for Universal engine parts?? Keep in mind, Universal just bolted on marine parts to an automotive engine so, take Kens's suggestion. |
B4nier
It separate from the transmission, I would think that they would be interchangeable.
Did they use the same velvet drive transmission for all the boats of those years such as the interceptor motor the Chrysler the universal. Just curious just trying to understand a way to make this work that’s all. Any information is very helpful |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
B4nier
And yes it has a port side helm, along with a forward reverse shifter and foot throttle, love to show pictures but real not sure how.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
The place in the link lists quite a few 198 Buick parts and with a name like Old Buick Parts they should be able to help hopefully.
I've never dealt with them, just dug them up on a Google search. A phone call would probably get any questions on availability answered. link |
B4nier
I would love to but have not been able to find bearings or any other rebuild parts, like gaskets etc.
If you have any suggestions of where I may find these parts it would be appreciated. Thanks |
This may be rather silly of me to ask, but why not rebuild the original engine?
A spun bearing isn't the end of the world unless you spun pieces parts right out of the block |
B4nier
What would be your Suggestion where to look for these parts?
Still learning how to put pictures on |
B4nier
My grandfather bought this boat new in 1965. I’ve
Been trying to keep it with the 198, but have been looking for several years And haven’t had much luck. Hopefully we can find A donor boat. I started skiing on this boat when I was there Years old, would love to get it going again. |
Bryan,
It sounds like you got caught in the Buick redesign when they went to the 225 block. Both engines used the Velvet drive 70c's which bolted up to I believe a SAE #3 bolt pattern bell housing. You may end up having to get a complete 225 engine to get the housing. Be patient and do some searching for used take out's from re powers. Welcome to CCfan. How about some pictures of the 65? We'd love to see what you're working on. Does it have a port side helm? |
B4nier
The 198 spun a bearing. So figured the 225 was the next best thing.
The 225 is out of a inboard our board, it’s a Volvo pent 1965. The bell house is close. I would assume that that same transmission was on the super Sabre 225 with the correct bell housing. |
63 Skier
Transmission is a 1:1 Velvet Drive AS1-70C. Was the 225 you are using in an inboard boat? Curious what transmission it was mated to before. While the 2 engines don't have much in common, I figured they were both mated to 70C's. Maybe I'm wrong.
What's the reason for the engine swap? |
B4nier
Any one have any info on transmission used in 65 I have 65 America Skier with a Sabre 198 and changing it out and installing A super Sabre 225. The bell house doesn’t line up. Would like to use the same transmission if I can Find the right bell housing. Any info or help would be appreciated |
