502 exhaust manifolds |
fvmako17
Newbie Joined: October-08-2017 Location: cape cod Status: Offline Points: 6 |
Posted: April-26-2018 at 9:37am |
Thanks I will check it out
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Maybe you tried this place in the link, maybe you didn't.
link It let me put 2 in the cart without any little message popping up to say they're out of stock. Maybe they have them, maybe they don't but a phone call should tell you. |
gt40KS
Gold Member Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Ok, never mind .... just checked Stainless Marine and they are compatible.
JCCI
1995 Ski Nautique GT40 |
gt40KS
Kenny, you may want to double check that manifold that Terry posted above. Looks like it's for a traditional BBC - i.e. 454 -- I'm not 100% sure that will work for a 502
JCCI
fvmako17
risers are similar but its size, angle, and length are different. i think 3" common but these are 4" or 3 1/2"
They are also long from top of riser to outlet. http://inetmarine.com/pcmr029004riserexhaust454.aspx |
Thought all the risers were the same no matter what engine or displacement or is a 502 different from a 454?
skidim link to risers |
fvmako17
thanks
fvmako17
thanks. i think the harder part is the riser. it is part #R029004 but i cant find it.
gt40KS
Being a GM block, you might look at Mercruiser replacements. You'd likely have to change the manifolds and risers and also extend or at least modify the exhaust hose thereafter to make it work for your app, but it's a start
JCCI
fvmako17
recently tried order new exhaust manifolds and risers for a 99 nautique super sport with 8.2L 502 python motor. They do not make anymore (discontinued) Does anybody have an idea where I could get or something that is close? thanks
