First Boat - Bent Keel and Broken Bow Eye |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2974 |
Posted: May-31-2018 at 1:01pm |
My 1994 had a slightly bent front fin for several years. After removal and straightening the fin, I did not notice any difference in steering, tracking or handling. FWIW.
JQ |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 915 |
So, the LIFTING RING, which is what you have illustrated, is threaded onto a vertical rod that is firmly anchored into the hull. Then is is secured by 2 screws (one of which it sounds like you broke) to prevent it from spinning. It is primarily used for lifting the boat off the trailer, or suspending the boat in a boat house. The BOW EYE (which is not illustrated) is a u-shaped ring mounted below the deck (at the front) and is used primarily to secure the boat to the trailer, or as a tow point when disabled. |
'I measured twice, cut three times, and it's still too short!" |
Payton,
A word of caution regarding the bow lifting eye. Did the PO use an extended pylon and if so, did he have the pylon cable connected to the lifting eye? If so, the cable should be connected to a strap around the stem and not the lifting eye. If connected on the lifting eye, it applies a rearward pulling force that can damage the deck. |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
On your Pro Tech, I believe I have read that set up ran really strong, until they don't.
MrMcD
I have not looked at my 95 bow eye but my 78 had all thread that screwed into the eye and went through a bracket that is fiber glassed into the bottom of the hull. below the nose. The all thread bolted to the bracket. Just go up in under the hull and inspect. I would not tighten against the hull you might break the fiberglass. Just make sure it is snug and then use two wrenches and tighten the lower bracket nuts against each other while being careful not to pull your bow down and damage the fiber glass. It is for lifting vertically.
If you need to be towed connect to the bow eye below the bow where your trailer hooks up. |
Payton91
Newbie Joined: May-28-2018 Location: SF Bay Area Status: Offline Points: 16 |
Haha thanks for the tips! I took the boat out on Monday and.. Protec be damned, the boat ran great!
I didn't notice anything drastically bad with the handling (especially when turning) but may need to test in glassy water. The steering wheel was about 70 degrees turned to the right to go straight but I'm not sure if that was the keels effect so I may just take the steering wheel off and spin it back. I'd rather not go through the process of fixing the keel until I have some more boating driving hours under my belt. For the bow eye - does anyone know how it's attached within the hull? I figure that it's bolted in with some nuts on either side of a chassis mount and the nuts loosened up. Doesn't sound fixable without a major tear up so I may just make sure it's sealed well. There was only one screw in the two holes when I got to it and when I tried to remove the remaining screw the damn head broke off. I'm guessing people are going to be pulling on it for whatever reason and I'm going to cringe every time. Anyway, boat is awesome -- changing the fluids and impeller along with some cosmetic touch ups this weekend. Thanks Payton |
Woody, Lets not take Payton back to the old days at CC or their distribution centers! |
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 378 |
2 hammers will fix the fin
woodyelc
Payton,
The tracking fin can be straightened cold in an arbor press. It doesn't take much force. |
MrMcD
Welcome aboard, you bought a nice boat. Nautiques will show the quality of build more and more as you own it.
If you choose to straighten that front fin they don't fall off when you take out the screws. I think they are also glued on with 3M 5200 and it is pretty strong adhesive. A simple method to remove it once the srews are out is to take wooden door shims, they sell them at the hardware stores, tapered shims about 10" long and 1.5 inches wide. They taper down to sharp points. I took these shims and started tapping one in between the boat and the Fin base. As soon as one shim starts to go in start another beside it. Get 3 or 4 going in at the same time and it will pop off the fin without doing any damage to your hull or the fin. The dried adhesive will still need to be scraped off the hull. I used a automotive gasket scraper and it took the old glue off quickly. I used the wire wheel of a bench grinder to clean the base of the brass fin. Maybe others have faster or easier ways to do this but this worked for me. I do not know how you should straighten the fin. I would think you would need to heat it to help straighten it. I would wait for advice before trying. Someone will chip in good tips. |
Payton,
Welcome to CCfan and ownership of the 94. The tracking fin can be removed and straightened. I'd see how the boat handles first. The eye on the fore deck is the lifting eye and not a bow eye. The eye has hardware that runs all the way down to the stem for the force applied when lifting. Pulling force should not be applied to it. It can be used for mooring but that force is minor. Replace the machine screws fastening it to the deck. |
Payton91
I just picked up a 1994 Sport Nautique and I'm finding a few things wrong with it now that I have it home.. Look for a recommendation on these problems.. fix it or leave it alone?
First keel fin is bent: Upper bow eye screws are missing and it rotates freely - not sure how this is attached and if it was ever meant to support much pulling force. |
