Shifter/starting problems 2000 |
SNobsessed
Posted: June-29-2018 at 3:49pm |
Check the lanyard safety switch. Try bypassing it for test only, don't boat this way however.
david36
Newbie Joined: March-06-2017 Location: Michigan Status: Offline Points: 12 |
2000 Air Nautique
If anyone has any suggestions on what I can try to trouble shoot next would greatly be appreciated. Installed new throttle cable. The boat will turn over, however will not start? The throttle cable was adjusted. Suggestions? |
david36
Hello,
Replaced throttle cable on a 2000. Having problems starting. Won't start and hold idle. It does turn over. Not sure if there is problems with the shifter? The gears seem to look okay, however seem to be having some problems with neutral button that is installed with a small screw at the shifter. Suggestions on were to start trouble shooting? |
