Fuel water seperator |
Bri892001
Posted: July-10-2018 at 1:11pm |
I'm thinking maybe the carb itself? If you're getting excessive dripping from the boosters, your engine might be choking on the extra gas at lower RPMs, but above a certain RPMS, can slurp down the excessive without it being noticeable.
After your start your boat and warm it up, open up the engine cover and get prepared to quickly remove the spark arrester. Then shut down the engine, remove the spark arrester, and look down the boosters of the carb. If you still have a drip, you have an internal leak. Tell us what you find. |
propsorjets
Newbie Joined: May-23-2008 Location: United States Status: Offline Points: 12 |
My 88 2001 Nautique is running rough from idle to 2200 rpm.. it runs completely smooth above that. Could it be the water separator?
Props or Jets
