Stereo Install Questions |
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 388 |
Posted: July-30-2018 at 1:04pm |
Anyone else have pics of their install? We can create a sticky so others can see! A visual is worth a million words!
Otto
91NaughtyQ
Senior Member Joined: July-27-2015 Location: NC Status: Offline Points: 289 |
Will do. |
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001 |
91NaughtyQ
I put the battery in a battery box located under the closed bow section.
1991 Ski Nautique
gt40KS
Gold Member Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Yes Gary, let's see some pics of the install
JCCI
1995 Ski Nautique GT40 |
Otto Throttle
Where and how did you mount the second battery.
Thanks |
Otto
91NaughtyQ
Got it all installed today. 2nd battery, switch, and amp. Sounds and works great. Thanks.
Gary |
1991 Ski Nautique
gt40KS
+1 -- Just remember not to use a deep cycle to crank your engine - you'll need that second battery system with a switch & isolator. |
JCCI
91NaughtyQ
Yep that is the plan on the weekends when the lake is slammed full. We anchor and float... Thanks for the info. |
1991 Ski Nautique
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
Sounds like the intent is to run the stereo while the boat is off, more than likely while anchored, means you will be draining and charging that battery frequently, i believe a marine deep cycle would be right up your alley.
-Spiral
'89 Sport Nautique |
91NaughtyQ
Thanks guys. That set up to the ACC worked like a champ. I am going to add a 2nd battery and switch.. What do you recommend. It will just be running the stereo for now.
1991 Ski Nautique
spiralhelix
yep, i concur with Throttle. Second battery only useful if you plan on playing tunes while engine is off and longer than ~10 min.. If you do choose a second battery, you will need some sort of isolator to keep your starting battery from draining, but still allows for your alternator to charge it. Many options out there. I went with this one for simplicity sake. Others have used the Blue Seas Switch.
-Spiral
throttle out
Senior Member Joined: May-11-2015 Location: Chelsea, MI Status: Offline Points: 153 |
+ & - to battery. You should have a couple spare ACC switches on your dash (my 89 did) and that is where you terminate your IGN lead. No need for a second battery unless you getting crazy.
1989 Ski Nautique 2001 351 PCM w/ 1-1.23
91NaughtyQ
I am adding a stereo to my 1991 SN. I have a couple of general questions to see what the best route is -
Do I need a second battery? - Pros and cons? If yes do I get a battery "switch"? Wiring - Do most of you just go Pos and Neg to battery and ignition to ignition? If so what is the best route for tapping into the ignition wire. Thanks in advance. Gary |
1991 Ski Nautique
