Complete Stereo Install Guidance |
AAM196 ![]() Gold Member ![]() ![]() Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
![]() ![]() ![]() ![]() ![]() Posted: August-13-2018 at 4:33pm |
Sure Paul anytime! FYI I told buddy with the 1998 if he wanted to sell that you were looking...
I saw the MMs slightly changed and I kinda prefer the older look and having the crossovers separate to just mount on the inside of the combing pads. Either way, if you are going the polk route and don't want to put at least 45 watts to each of them... save money and go with the DB series... There is a lot more on audio over at the other site! My focus was to build a stereo that sounds great, didn't invest heavily on it and takes up the least amount of space. My Sub is a 10" in a customs box that is mounted up under the bow on the hump (I do not have a heater). I would attach a picture but it is pretty well hidden (with amp) that it is hard to see; only the Kicker bass remote control knob and the inline fuse holder are visible mounted next to the perfect pass module. For me, giving up the least amount of stowable gear space was high on the priority list. The only thing I wish I had was a wired remote accessible from swim platform... |
gt40KS ![]() Gold Member ![]() ![]() Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
FYI - Polk mm651 is discontinued ... newer version is the mm652. Difference is external crossover modules vs speaker mounted modules. Most or all of the specs are the same but they also have different grills. Great speakers though - crystal clear and one of few on the market that actually will handle and reproduce decent bass without the addition of a sub. Thinking of swapping out my Kickers that are in the boat with the 652's - they seem to be a lot crisper overall.
Without the addition of a sub - and frankly space is a premium in our boats, so finding a place to put a sub may be a challenge anyway - a good quality 4 channel amp is all you'd need. Two that are worth looking at are this Fusion and this Roswell |
JCCI
1995 Ski Nautique GT40 |
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4127 |
Andy
If/when I ever find a Sport your going to be drafted for the stereo install. ![]() |
I like Polk or JL...
I'd go with 4 Polk MM651 speakers $400.00 1 x 10" Polk MM1042 sub $180 (not including enclosure) with a nice 5 channel amp between $350 and $850... just saw crutchfield had a Fosgate TM1000 marked down to $650 (from $1,000) that would really push this setup to max... JLs are super nice too but cost a bit more.. So you'd have about $1,600 in after receiver and wire etc. Throw another $300 in to do a dual battery setup. So 2 grand? is that a lot? |
So now that it appears that the solenoid/ isolator/ relay debate is over ...
Otto, there are two basic trains of thought with marine audio (in boats like ours anyway) 1) Clean, clear sound even at a relative high volume but mainly focusing on those either within the boat or in very close proximity. Generally, this type of system will be great for anchoring/ floating purposes and will marginally do the job while under way at slower cruising speeds. 2) Clean but booming sound for everyone within shouting distance. Obviously this type of system will do very well for those wanting to easily hear the music while at the end of the tow rope and also for those that want a veritable concert atmosphere while anchoring. While the second is appealing for a lot of folks it bears mentioning that the components for said system are almost always very pricey compared to the first. Further, the sound projection to those outside the boat will be very limited unless the projection speakers are mounted well above the gunwales, such as in pods on a wake tower. So again, the first questions you should ask yourself are: * Which scenario am I going to want to build for? AND * How much do I want to spend overall on the system? Depending on the specific answers to those two questions you are going to get 2 completely different product lines and price ranges. ![]() |
JCCI
2400# and no problems. ![]() |
rosconole ![]() Gold Member ![]() ![]() Joined: May-10-2008 Location: United States Status: Offline Points: 760 |
If you want quality loud Wet Sounds or JL , remember you get what you pay for...I have heard them all. We can piss off everyone at the sandbar with either of those.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
rebel skier ![]() Gold Member ![]() ![]() Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 777 |
Gotta luv having your chops busted by one of the respected experts on this forum.
Speaking of busting chops -- Pete what is the tow rating of your Subaru again? |
Right were the red arrow is pointing
Where in the Amazons listing does it state "solenoid"? BTW, it sound like you searched in Amazon for a solenoid? This is a solenoid: ![]() It's the push or pull part of a relay. Yes, some people do call start relays a "solenoid" but they are also the ones who call core plugs "freeze" plugs! ![]() ![]() |
Donald80SN ![]() Grand Poobah ![]() Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3900 |
If you check over at www.planetnautique.com ( Forums/ Audio) you will find more ideas. Also, many of those guys will buy a new G Boat and they immediately remove the factory system and do upgrades. You can sometimes pick up their OEM systems for a low cost. This was the case more when Correct Craft installed Polk Audio, which is great, but now Nautique is installing JBL which is an upgrade. Some are pulling those for Wet Sounds and others. Jeff , site owner, with Planet Nautique gets a new boat each year and he immediately upgrades the OEM to Roswell Audio. If you hit him at the right time you may hit a jack pot.
Second battery is not needed unless you sit in a cove for multiple hours with the music very loud. Playing underway or sitting for shorter periods of time does not take the entire battery. I am running 1200 watts and three amps and have no battery issues with one battery. However, I do not sit in the same spot for more than one hour. Getting Class D Amps are more efficient and use less battery. However, they require more upfront dollars to acquire. Many have gotten great results from Kicker, or Polk systems and they are not as expensive as the other brands. If you go with two batteries, do a site search for the following: Randy from Ohio ( Site Name) Hellroaring Battery Isolation. Several on CCFan have been very happy with this system and it automatically leaves you with enough juice to start the boat once the brass stripper pole is removed and it is time to leave the cove. A second battery in a 196 could have a negative effect on the ski wake if you are a serious competition skier or tuber. |
2002 Sport Nautique, GT-40, FCT2, Cover Sports, Tower Bimini, Inc., Wet Sounds Audio System, Star Gazer Wake Edition S. 1968 Ski Nautique, Holman Moody |
That may be the case, but it is "Amazon's choice for a continuous duty solenoid".
In my other boat I went a Clarion so that I could use the Clarion floating MF1 marine remote.
I mounted the floating marine remote to my dash so that I can override all the people turning up the music when I want to hear a skier or boarder. When in a cove, I can float around the boat and control the music from the water -- no need to swim to the stern. If mounted in a dry area, you can use any amp. Don't spend for a marine amp unless you don't have a dry area. Skip the battery switch. Get a solenoid that connects the batteries when the boat is running an isolates them when off. Then get a deep cycle or dual purpose battery for the stereo and amps. Then, forget that you have two batteries till it comes time to replace one of them. All that being said, for my Nautique I just use a blue tooth speaker, but am looking at a set of polk bluetooth speakers where you can have 2 connected to your phone at one time, to get better sound spread. |
rolleronariver ![]() Senior Member ![]() Joined: May-24-2016 Location: Rogers, AR Status: Offline Points: 195 |
We replaced ours with the kenwood kmrd772bt and added the kca-rc55mr dash remote to control it from the drivers seat and we absolutely love it. We have infinity speakers throughout the interior of the boat a 5 channel Pyle amp with a 12 inch marine pyle subwoofer and two 8 in boss tower speakers and it sounds pretty good. It's very clear sound even when your behind the boat boarding. The only thing I'm not super happy with is the pyle amp and sub. They're not bad but I'll probably be upgrading in the future to something a little better.
92 Sport nautique
Otto Throttle ![]() Senior Member ![]() ![]() Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 405 |
I have recently found out that being with out music on the lake kind of sucks! Rather than replace just the head unit I have decided to replace it all. I am looking for recomndations on complete set ups...Head unit, amp, and speakers. I don't need the highest of the high budget wise. Just a respectable setup! Please send me pics if possible. I really want a marine grade system as we use the boat and moisture gets everywhere! Also if you run a second battery, where and how you mounted it and the wiring you used. Id like to not use an amp, but I just know it will happen. We sit on the lake for an hour or two ski/tube, the sit some more so I am worried about running the battery low if i use an amp.
Thanks Everyone! You have always been very helpful. |
Otto
