351w heads and intake manifold |
great78
Senior Member Joined: October-04-2005 Location: United States Status: Offline Points: 103 |
Posted: August-22-2006 at 11:06am |
thanks for the info Jeff, sounds like good bang for the buck. I've been looking at props too. currently running an oj legend 13x16 4 blade which has great speed but the hole shot is lame and it has trouble with heavier slalom starts. anyway thanks for the info and enjoy!
jeffinohio
Newbie Joined: July-07-2006 Location: Madison, Ohio Status: Offline Points: 26 |
sorry for the late reply. but yes, the new heads and intake made a very noticable difference. my rpms went from 4400 up to 4800. much better power all around. better throttle response and an increase of about 3mph top end. I bought the gt40P heads which are less than half the price of the original gt40 heads. www.tristatecylinderhead.com has the heads for $500 a set. you must get the mounting holes drilled out to 1/2 inch. $25. it's the best upgrade you can do to your engine for $800 including intake and new gaskets. i also highly recomend the o.j xmp 13x15.5 4blade prop. best prop i have found for early to mid 90s nautiques. works better than the acme on my boat.
great78
jeff have you run with the new heads? I'm think of the same mods on my 96
jeffinohio
351w heads and intake manifold for sale. Just replaced them with gt40s and a performer intake. engine ran great when removed, came off my 92 with 590 hrs. heads have valves and springs. $250/heads. $200/intake. call jeff at 440-622-9517 cell. jllakatos@adelphia.net
