Solenoid Burning Up |
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
Posted: August-20-2006 at 3:55pm |
primary difference between a good marine cable and an automotive cable is that the copper on a marine cable has been tinned. And as in all applications, gauge versus distance is critical.
GottaSki
Yup, the contacts stick when they arc and weld together when the actuating voltage drops, holding force weakens due to the afformentioned reasons..battery type and capacity, small/inferior cables, dash connections/corrosion, corrosion in wire harness QD, etc
River Rat to Mole |
JEFF KOSTIS
Like mentioned, a cheap solenoid will give you trouble. Also make sure its a starter solenoid and not a continuous duty solenoid as you cant tell them apart from looking. Also make sure when installing a new one that you dont rotate the studs. Snugging up the jam nut against the solenoid body usually helps as they always seem to be loose from the factory on some. Generally if a hammer blow to it cures the problem, that means the contacts are stuck.
Jeff... |
boat dr
79 what is the difference between an automotive cable vs. an automotive type. batteries,soleniods,cables and even the new perm. magnet starters are the same as those used in the automotive industry. the new starters don't even use the sealing plate around the armature ,the solenoid is different,but only in that it has two term. on swich the other to energize the electric fuel pump during cranking.i dont see any difference in the cables. sticking solenoids are often caused from excessive amperage,dragging starter,too small on the size of the cable,ground or positive,cheap battery(wally world or auto zone). also cheap chinese solenoids,buy the stuff that came on the boat,PCM motor PCM parts.... skidim,SE correct craft,buy good parts and the heaviest battery your wallet can afford
cblars
Newbie Joined: August-14-2006 Location: Oregon Status: Offline Points: 9 |
I have experienced the very same issue on my 1980 ski supreme. In fact, Gotta Ski gave me some very good tips to troubleshoot the problem - Gotta Ski, thank you. My problem was related to the blower motor and a poor connection at the dash. If I tried starting the engine with the blower on the solenoid would stick, keeping the starter engaged - tapping on the solenoid would free it up. I checked all the grounds - cleaned them up, etc. However, I found the connection at the dash for the blower motor was loose (on the fuse block). Not only was it affecting the starting, but the nav. lights would illuminate. After correcting the poor connection I have not had any problems. I guess the short version is, check for loose connections - grounds and otherwise.
GottaSki
Yup, and no Marine Deep Cycle battery, those are for fish motors.
River Rat to Mole |
79nautique
well the battery needs check for CCA rating and the cables need to be inspected as well for corrosion and undersized cable or if an automotive cable was used on marine engine.
Hal A
Newbie Joined: August-18-2006 Location: United States Status: Offline Points: 3 |
I have a buddy with an odd issue. His solenoid is sticking in the closed position so that once engaged it won't stop. He has replaced it several times and still has the problem. It does not happen every time but when it does, the only way to stop it is either let it burn up... not what he does... or disconnect it from the battery.
Any thoughts? |
