  New Posts New Posts RSS Feed - Carb Issues
Carb Issues
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Topic: Carb Issues
    Posted: August-21-2006 at 9:09am
Yes, 8-10 is best. Also set your air screws when idling in gear. Off-idle will improve.
Make certain there is noi slop in the accel pump linkage, too.
You make have a vacuum leak too.
River Rat to Mole
MY70/81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MY70/81 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2006 at 8:58am
I am looking for some advice on my 81 SN. I have spent my summer sorting out several problems left to me by the PO, and I believe I am pretty close to having it right. I have a nagging problem with the idle on my 351, so far this is what I have done, set Timing to 6 degrees BTC, adjusted Points, Plugs, Rebuilt Carb and set everything to rebuild specs, I also previously replaced one Piston, and the Lt side Head. I am having a lot of problems getting it to idle until completely warmed up, and it has a slight stumble pulling from a stop. I have read some posts that say the Timing should be 8-10 degrees? I am kind of new to the 351, because my 70 SN has the 318 in it.
