250hp OMC distributor |
Tim D
Posted: August-23-2006 at 4:29pm |
This is the kit.
Tim D
southwind 20
Newbie Joined: August-08-2005 Location: United States Status: Offline Points: 30 |
Thanks Tim...do I need to use the original points plate? Mine is all stripped out.
Git One ON!
Tim D
It is a marine part. $139
Tim D
southwind 20
just wondered if it was ok for marine use for the inspection...what was the cost?
better get to bed...Ill check back tomorrow and thanks much for all the info guys! |
Git One ON!
Tim D
I've got the conversion, it works.
Tim D
southwind 20
well I cant get the link to work now so I dont know what I did. What so you think of TimD,s idea about the napa conversion?
Git One ON!
southwind 20
Git One ON!
79nautique
the wirings easy all you need is the positive lead to run to the HEI you'll have to ask awhite70 about the tach lead not sure if you can just run the neg to the tach terminal on the dist or if you have to run a new wire to the tech lead on the dist.
not sure on the actual ebay auction bring it up and copy the link and paste into the window that comes up when you hit the globe looking icon just above the message window your typing in. |
southwind 20
What so you think about this conversion 79 Nautique?
Git One ON!
Tim D
I bet the NAPA part # 18-5296-2 conversion kit will work. It is for Mallory YL and YD distributors.
Tim D
southwind 20
seems I have found one on ebay, OMC and Mercruser 350 GM ...say it will fit 305 through 540cid. Used stock dist.
ebay #190022833597...think it will work? Also not sure how to convert wiring. |
Git One ON!
southwind 20
Just trying to figure out what I need to put in the ebay search
Git One ON!
southwind 20
Not to keep asking stupid questions but do I look for one for a GM350 then? Do I need a special marine type? Thanks again
Git One ON!
79nautique
a marine unit but you will have to use your gear on the current dist due to the reverse rotation
southwind 20
It's inboard with right hand rotation...any special type of HEI? Thanks!
Git One ON!
79nautique
there are a lot of options on a new dist, HEI, MSD, Mallory i would pick-up an HEI unit off of ebay or get a nice MSD. Is that an inboard or a I/O set-up with standard rotation?
southwind 20
This is pretty much the same post I left in parts wanted but mabye you guys can help.
I have a 1976 Southwind 20 with the 250 OMC (350 GM) engine. I want to replace the original distributor with an electronic one or convert the original one over (bad points plate). I remember last year there was alot of discussion on conversions and alot didn't work for certain applications. This has a Mallory single point dist...part # is unreadable. Is there a conversion that will work well? Thanks! Jeff |
Git One ON!
