  New Posts New Posts RSS Feed - Tach Repair
Tach Repair
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: Tach Repair
    Posted: July-30-2004 at 2:30pm
Yes, absolutely. Good point, always check for good ground first thing when troubleshooting guage problems, especially erratic guage movement.
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2004 at 4:19pm
hay david f..could it not also be a bad ground wire to the tach ?
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2004 at 3:00pm
SnoPro:
Your tach is bad, replace it.
DDSUPPLY:
Tachs have one or two wires/terminal connections. One is ground, and the other goes to the NEGATIVE side of the coil. If you connect it to the positive side of the coil, you will peg the tach and possibly damage it as it will always be getting line voltage. When hooked to the negative side of the coil, it is measuring the frequency of the coil discharge. This frequency changes if you have a 4, 6 or 8 cylinder engines, so the tach must be proper for the type of engine you have. Some tachs have jumpers on the backside to select the number of cylinders.
Usually, the wire is black from the tach to the NEGATIVE side of the coil. A brown or green wire usually indicates ground.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2004 at 2:16am
Try turnuing the key on and off see if that resets the Tach. Mine always read 1K after I shut it off until I turned the Ign on then off without starting.
SnoPro150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SnoPro150 Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2004 at 9:01pm
Is there any way to adjust a tach on a 78 tique. It seems to go up and down right with the RPM but always reads to high even when the engine is not running.
66polyhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2004 at 9:11pm
The airguide tach on my 66 is for a v-8 only. the two wire leads are black and brown. It sounds like Rick is on the right track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2004 at 12:05pm
DDSUPPLY page 34 on the chrysler marine manual.wire # t-1 is dark blue goes to a "cowl panel plug in connector" good place to start checking.from thereit runs back to F ignition relay. from relay to + side of coil it shows J wich should be a tan wire and has an in line resister.
wich ? witch which i need to go back to skool.
kenny g
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2004 at 4:56am
Black Ground Green + coil yellow Ign. Brown - Coil Wuould be my guess
DDSUPPLY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DDSUPPLY Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2004 at 6:17pm
I checked continuity--it is ok. The rest of the wires have been cut loose. I don't know why. There is a green-black-yellow-brown wire coming from the tach. have tried various combinations. the gauge will peg on one try, so if anyone does know the correct wiring let me know. thanks
yellowdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2004 at 4:51pm
DDSUPPLY,
Forgot the most important thing to check! The ground wire. A loose screw, nut or a bit of corrosion on the ground wire or terminal can drive you nuts trying to find a problem.
Another item could be an ignition wire. For a long time boat and gauge manufacturers used just 2 leads for the tach; a 'hot' lead from the distributor and a ground. Somewhere along the line the gauge companies added a terminal that wired to the ignition switch. It's a purple wire today.
Caretaker of the wife's '78 Ski Nautique
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2004 at 10:56pm
I beleive the Tach wire in my 66 is green. It does attach to the + side of the coil
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2004 at 6:40pm
The tach wires into the positive lead that runs from the coil to the distributor. Today's standard is for a gray wire to run from the dist. to the tach, don't have a clue what they did in '65. Check the continuity of that wire first.
Not a lot to go wrong with a tach. But they do go bad sometimes. Unless you want to stay with the original style, replacements are reasonable and easy to install. Matching the original will be hard to do and finding someone to repair an old one may be tougher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DDSUPPLY Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2004 at 1:57pm
   On my 65 Barracuda -The tach does not work,is there a test I can do to see if it does work and maybe the wire is just broke or loose? Where does the tach wire attach back on the motor?
