  New Posts New Posts RSS Feed - DUI Distrubtor
DUI Distrubtor
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Topic: DUI Distrubtor
    Posted: August-18-2018 at 11:18pm
Originally posted by ArtCozier ArtCozier wrote:
[QUOTE=Mooney Pilot] I have a 1984 2001 I bought new. I'm in the process of replacing the distributor to a DUI unit. The engine is a Commander 351 opposite rotation. I bought the DUI reverse rotation and installed it. I can't seem to get the engine to run.
Question,
Is this the correct distributor (reverse rotation)?
The rotor turns counter clockwise is that correct?
Firing order is 13726548
Any help would be appreashed
    1-8-4-5-6-2-7-3
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2018 at 11:17pm
Question,
     1-8-4-5-6-7-3-2
"Art"
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2018 at 8:40pm
I seem to get the distributer 180 off half the time I'm pretty sure that makes me wrong only 25% of the time
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2018 at 10:38am
FIXED. Thanks for everyone's help. Distributor was 180 out If anyone's interested I have a Mallory breakerless distributor and coil I'll sell cheap. I installed the DUI because I was burning out coils. The coil is brand new.
Dennis,
Glad you found the problem and we were able to help. If it makes you feel any better and just as Ken mentioned, many including myself have gotten a distributor 180 off.
Welcome to CCfan. Stick around and any pictures you have would be great to see. The 2001 is a classic!
The coil problem sounds like a wiring issue you had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 11:49pm
Glad it's fixed
Don't feel like the Lone Ranger though.
You're far from being the first person that this happened to and you definitely won't be the last either
Mooney Pilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooney Pilot Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 11:03pm
FIXED. Thanks for everyone's help. Distributor was 180 out and I was using the wrong firing order. If anyone's interested I have a Mallory breakerless distributor and coil I'll sell cheap. I installed the DUI because I was burning out coils. The coil is brand new.
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 10:18pm
Originally posted by SNobsessed SNobsessed wrote:
Maybe a PO changed the cam, who knows.
He is the PO, he bought the boat new
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 10:14pm
You could always remove plugs & get firing order from thumb pressure over the holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 10:12pm
You might want to read the manual again and make sure you're looking at a reverse rotation firing order.
Cuz' what I gave you is the reverse rotation order
No matter which order you're using you go counterclockwise around the cap because the rotor turns counterclockwise on a normal rotation engine and also on a reverse rotation engine
Are you sure that you have #1 at 10 degrees before Top Dead Center on the compression stroke when it's firing?
The backfire through the carburetor sure sounds like you have #1 at 10 degrees before TDC on the exhaust stroke.
Or in other words your timing is 180 degrees out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooney Pilot Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 10:03pm
The firing order I posted is out of the Commander service manual. I started with your firing order and It was back firing thru the carb. The timing is set at 10 btdc. ???????
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 9:58pm
Your intake may have the firing order cast into it, but it's an automotive intake being used on a reverse rotation PCM engine so you can't go by that cast in order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 9:55pm
Question,
Like Duane said, if the distributor fit in the hole and the gears meshed, it's the right distributor.
The wrong thing though is the firing order you're using.
13726548 is the normal rotation firing order
You want 18456273 working your way counterclockwise around the cap
So swap those wires around and it should run if you have the timing set OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooney Pilot Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 9:52pm
The DUI unit has the coil on it. That's why I bought this one. It only needs 12 volts and tach wire. should have been very easy to wire.
Thanks for the reply.
Dennis
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 9:47pm
They all turn CCW
You could not get it to set down onto the flange if you had the wrong gear.
Don't have the firing order in front of me but surely Ken or someone will chime in.
Also make sure you have the correct coil and have dist wired right
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooney Pilot Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2018 at 9:29pm
Question,
Dennis
