Edelbrock secondary flooding |
wiscofoot
Senior Member Joined: February-16-2018 Location: Neenah, Wi Status: Offline Points: 124 |
Posted: August-27-2018 at 12:29pm |
Sorry, it is an early seventies MC Stars and Stripes. I am back in the Midwest so it’s his problem now. Thanks guys. It’s for sale and in nice shape if anyone is interested pm me. I think he said around $6k
1976 Martinique
Agree no need for the cam Why the Edlebrock? It's a 302 but what boat is it in? |
Not positive about Edlebrocks but marine carbs don’t have or need a fast idle cam, you pull the knob on the control and manually increase the engines speed.
Dumping fuel is the least of his problems if he was driving it down the road and hit a bump |
wiscofoot
Pouring in both of the rear barrels. Front barrels appear to be atomizing fuel normally. I will pull the top and take a look. My brother had the carb serviced and then hit a large bump on the road. He then noticed that the fast idle cam was missing. He got a new cam but this marine carb doesn’t have the fast idle adjustment screw. Any chance something wrong with the choke/fast idle linkage could be causing this?
1976 Martinique
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6150 |
Pouring from both sides or just one?
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 378 |
Remove the screws around the top and lift up and you will see the needle that has a piece of something on it causing the flooding. If you r careful you will not tear the gasket.
woodyelc
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Bowls are on the side, IIRC... Eddy’s dont like being installed at an angle.
wiscofoot
Hi guys. Sorry for the desperation post....in rural Wyoming for a family wedding and trying to help my brother get his boat running. It’s a 302 with an Edelbrock 1409 (performer series) and the secondary side is pouring fuel out of the top at idle and under throttle. I haven’t worked on one of these before and I am assuming it’s either too much fuel pressure or the float set too high or junk between needle and seat. Not able to get to an auto parts store but I have a regulator being overnighted, will be here tomorrow. Any other advice besides checking these things? Only have an hour or two tomorrow to work on it and if I can’t fix it it will probably cost him close to a thousand bucks to get it worked on in time.
Cole |
1976 Martinique
