  New Posts New Posts RSS Feed - 1965 CC cuda??
1965 CC cuda??
00065cccuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Topic: 1965 CC cuda??
    Posted: October-22-2018 at 10:33pm
The stringers were doubled up and a mess maybe I'll get lucky and find the ID tag when I start taking them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 10:30pm
From what I was told the ID tag is non existent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 9:45pm
If you were to post the serial number,it should start with a B and be on a aluminum tag attached with roofing nails on the port stringer,roughly about where the trans connects to the engine, I'd venture to guess someone here will know the approximate year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 9:19pm
Posted pics from my home computer worked fine I will take more pics of the inside of the boat and engine before I start. Thanks for the info was thinking it was a barracuda. Think I should go with a 289 or 318 to keep it original?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 9:02pm
Jim,
Glad you got the picture posting figured out. Thanks for the pictures. keep them coming especially when you get into the stringer replacement. Do you have any pictures of the engine? Do you think it was the original engine? Yes, it sure looks like a Barracuda.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 7:52pm
finally got some pics of the boat up I think its a 1965 barracuda not sure couldn't pass on this one got it for 400 bucks has a 65 ford 260 with 289 heads looks like the original trailer and the tires. just purchased a 65 289 complete ready to go to the machine shop and while that's being done I'am putting in new douglas fur stringers and a new floor. That should keep me out of trouble this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 7:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 7:30pm
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 4:26pm
There was a bellhousing change from 260 and early 298 to later 289 engines and those afterward. Relevant, just not something to not freak over if things look odd to you.
Also 260 and 289 have the same stroke, so you can use the backerds 260 crank in the 289 block to make a reverse 289.
River Rat to Mole
outerbanked View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote outerbanked Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 3:12pm
Your close. You need to view your pic in another web tab so you get the whole url: to copy. something like this
http://correctcraftfan.com/forum/uploads/17712/20170715_160512.jpg
See yours is just the local file name to ccfan (after the last / )
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 3:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote outerbanked Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 2:58pm
Some devices will not use the website's routine. There is an easy workaround once you learn how to "code" html. It is easy. You need to tell web browsers that you intend to reference another url. (Your picture). The first set of [ ] define the start of the img tag. Then your Http reference. Then the last set of [ ] tell browsers that the image tag is ending with [/img]. This is the structure of html. TheRe are tags for bold, colors, links,etc.
Try this:
Click reply.
Then click on the pic of the tree. Then just click "ok".
Notice the txt that appears. This is the html (hypertext mark up language) tag for rendering an image to a webpage. < IMG]http://[/IMG > . This one is using the wrong outer brackets, but I am posting it for those who are reading
If you switch to "basic mode" from "prompt mode" (drop down button a few to the right of tree), you will get the same without the start of your Http url reference. Once you understand this, you can type the img ref yourself and not use the buttons. On a phone, the prompt and tree method give you a larger target to highlight with your finger to paste over.
If you upload your pics using this site in the control panel, zoom out and on some device you will now realize there is an entire right side of the page you do not see. You will even see your uploaded pics.
Select your pic from your directory. Click and hold on the preview of the pic and then open in new browser window. Highlight your url in the address bar and copy it.
Now take that back to your post. Paste it into the image tag between the ][ where the http:// was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 2:43pm
I will try later today to post pics on my home computer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 2:40pm
Thanks for the heads up I have been using my phone to upload pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 1:49pm
This works on a desktop or laptop.
It doesn't work on a phone, tablet etc.
Jim,
What are you using to load the pictures from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-22-2018 at 1:28am
Try following the directions in this link to an old thread.
When you get to the 3rd step where the big arrow is pointing at browse, it may say "choose file" instead of "browse" in that box. Click on that box and continue following his instructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 10:19pm
Do you need to buy something or donate money to download pics?? I must have registered wrong or something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 9:15pm
Originally posted by 00065cccuda 00065cccuda wrote:
Nothing happens after I hit the pic with the arrow no menu pops up
Read again. There are two icons with arrows.
Click the full reply editor. It's the slanted arrow icon above the quick reply Then click on the icon of the tree with the up arrow. A browse box will come up allowing you to select anything off your computer.
Full reply editor first (arrow above)
Then icon of the tree with the up arrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 9:01pm
Love the pic that's great! Nothing happens after I hit the pic with the arrow no menu pops up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 7:06pm
Not working when I hit the tree with the up arrow??
Works for me. What did you do after you clicked on the tree? Did you select a picture and then click OK?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 5:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 5:21pm
Cant figure out how to post pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 4:29pm
Jim,
If it's a 1965, the 16.5 length would make the boat a Classic model and several V8 Interceptor Fords were available (listed). Pictures are needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 10:22pm
The length is 16'6 dark red on top with a air scoop in front and raised ribs in front and rear. I will upload some pics soon. Thanks for any info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 10:17pm
The 289 is not a marine engine and not sure if the 260 the boat came is either
Marine engines have been derived from automotive engines for many years. It's basically bolt on's that make a engine marine and not it's rotation.
Yes, as Ken mentioned, pictures are needed. What's the length? I'm going with what you have is a Mustang.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 10:09pm
Maybe pictures are needed so you can verify just what model you have.
As far as the engine, only you know what your budget is and how "correct" you want to make things
318 reverse rotation Chryslers aren't exactly a dime a dozen and parts aren't very easy to find either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 10:06pm
Thanks for the info going to need all the help I can get I would like to put this together the right way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 10:01pm
I don't want to rebuild the 260 I would rather the 289 but if the boat is a barracuda I should do a 318 to be correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2018 at 9:56pm
